sunroof question - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 04-28-2011, 06:58 AM
claver claver is offline
Mein Auto: 1997 328i
Question sunroof question
I have a little problem i created myself, my sunroof was perfectly fine, worked perfectly. one day i left the lights on battery went dead, sunroof opened and started to rain.
Long story short, i went outside running couldnt close the sunroof and it was about to pour. So i grabbed a ratchet and closed manually. Now went i try to opened electrically i just make a sound like its stuck on something and it wont open at all. The motor is good. The parts have grease as they should, everything was good until them.
I dont wanna take it apart if i dont have to, what can i do?
Old 04-28-2011, 07:49 AM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
I have a vert so I dont have a sunroof but based on experience, it sounds like when you closed it manually, you did it too tightly and the electric motor can not over power how tight it is. Try loosening it.
Old 04-28-2011, 09:11 AM
sounds good ima give it a try, thanx
Old 04-28-2011, 07:34 PM
It didnt work, i opened up manually and still giving me the same problem.
Old 04-28-2011, 10:44 PM
CHIF8008 CHIF8008 is offline
-Freedom-
Mein Auto: E30 325es
check the tracks for dirt and possible metal shavings.
when you closed it manually- did it close with minimal effort? or were you torque'n on it?
Old 04-28-2011, 11:32 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
You can try and reset the sunroof. I have done it before on my previous E39 because I replaced my battery. It might work for your older E30. worth a try at least
push the tilt button and hold it for at least 10 seconds. This should reset your sunroof and give you full functions again.
If this does not work, you can also try to push in the entire slide butting and hold it for as much as 3 minutes (i held mine that long, that was what i was informed to do and it worked!)
in this time span, the roof should have moved about its normal operation trying to recalibrate itself.
hope this helps.
