Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 04-29-2011, 01:01 PM
Babysbmw Babysbmw is offline
Mein Auto: 528e
Unhappy Need help despraite
I changed the timing belt on my 85 528e got everything set back and put back together only now it won't start. PLEASE I need help!!
Old 04-30-2011, 02:28 PM
catso's Avatar
catso catso is offline
catso
Did you align the timing marks correctly? Check and see if you have spark. Did you use a Bentley manual for reference. It's pretty detailed and probably provides the best step by step guidance if you haven't done this before.
Old 05-05-2011, 10:22 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
If you did a quick remove and replace without moving enything your car should have started right away. Double check your timing to make sure that you were on TDC (you might need to remove the #1 spark plug for this). And check every plug by disconnecting, cleaning and re-connecting. Take a look at the fuses and if you have never repalced the main and fuel pump relays, maybe is a good time to do it.
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
