Old 04-30-2011, 12:07 PM
kpg0628 kpg0628 is offline
Mein Auto: 540i
How to remove a broken water pump stud
While installing a new water pump on my 97 540i, the long 4" bolt broke. This left a 1/2 stud deep in the engine block. Anyone suggestions on how this can be removed? Will an ez-out fit that deep in the block? I was also wondering if I can just install a plug and use a smaller stud? Any suggestions would be greatly appreciated.
kpg
Old 04-30-2011, 05:34 PM
repcapale repcapale is offline
Mein Auto: 2014 535 XDrive
So there is about 3.5" of empty space now before the broken part is what you are saying. That bolt must be 4" long for a reason otherwise i would just get a 3" bolt and drive it home.
Old 04-30-2011, 06:43 PM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
I
Would REMOVE IT. Our cooling systems are unreliable enough, don't give it another 'weak point.
If you have access to it ez out it. the water pump is off I am presuming and you could touch the broken bolt...BTW, how did it break? Cross thread or?
Kind of matters as to which technique to remove. If the threads are undamaged, then you may be able to chisel a slot in the end and screw it out like a screw, if it is crossthreaded you may have to get a sharp drillbit, either cobalt, or titanium and drill out the center before using the easy out...
GL
This is NOT a honda or toyota, don't jury rig anything...
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 04-30-2011, 08:06 PM
Mein Auto: 540i
The bolt snapped while securing. It's a very small opening (looks like an m8 size). I'm not able to find a small drill bit or ez out that's long enough to reach 4 inches deep. I don't like the idea of rigging it but I can't seem to find an better solution. Will it cause any problem to tap the hole or plug with an insert and then use a shorter bolt to secure?
Sent from my DROIDX using Bimmer App
Old 05-01-2011, 08:38 AM
GL
Jury rig? We use a different word up here.....
Old 05-01-2011, 10:48 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
"Jury rigged" is a long-established term from sailing, meaning rigging that's improvised or makeshift.
BMW--giving new meaning to the phrase "disposable income."
Old 05-01-2011, 10:54 AM
Yes thank you for that Bob, but I was just joking.
Old 05-01-2011, 04:02 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by bobdmac View Post
"Jury rigged" is a long-established term from sailing.
I always wondered about the genesis of that expression! I thought, off hand, it had something to do with bribing a jury - but that wouldn't make sense. I didn't realize the "rigging" was the operative word, not the "jury".
As for the OP's problem. Yikes. Ugly. You make even bigger mistakes than I do! (ooops. That doesn't sound the way I meant it to).
I, for one, would also vote to remove it, as best you can (same sentiment as was already said, our cooling systems are jury-rigged enough by the Bavarian engineers, not to add yet another weak link).
Do you think you can get a screw extractor in there?
Old 05-02-2011, 07:13 AM
Mein Auto: 540i
Don't think I could get a screw extractor in there. It's a 4 inch deep opening. The thread is on the last 3/4" inch of the bolt. The bolt snapped off near the thread.
Old 05-02-2011, 08:26 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i, 2005 X3
Do you feel lucky?
You really don't have many options with a stud broken that deep. The most important consideration at this point is to not make a bad situation worse. The only thing you may have going for you is that there should be very little prevailing torque on the broken end if you overtightened the bolt. With that in mind, here are 2 suggestions:
You could try taking a clean piece of steel rod & try to epoxy it to the broken end. The probability of it working isn't that great, but you won't mess anything up by trying it.
If you can find a long drill bit of the correct size for the ez out, you could braze the ez out onto the end of a long piece of steel rod & then use to extract the bolt.
Old 05-02-2011, 09:22 AM
Burning2nd's Avatar
Under the lift arms
Left handed drill , start with a 1/16 or 1/8 I don't know what it looks like but I sure I could get it out,
You might want to find someone who's a little more confident withthis or you might be having bad day ahead
Left handed drill is key word for u
send from space command
15486372<-----
Old 06-20-2011, 12:19 AM
bluebee's Avatar
Today, in reading a thread from someone with a similar broken stud:
- E39 (1997 - 2003) > Water pump issue
I searched and found this thread. So that others can benefit, what did the OP end up doing as a solution?
Old 06-27-2011, 02:00 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Look, I did the exact same thing and the hardest part was finding a new bolt that diameter and thread pitch. It is another BMW F-up. I had to order a few through Fastenal. If you want to PM me with your address, I might be able to find one and send it to you. If you buy from Fastenal, it will be a stainless bolt instead of the cheap ass aluminum bolt you have-maybe it's steel, but it's like pot metal. If your old bolt is broken-off farther down below the block surface than the bolt diameter, then you will get full strength leaving the old piece in there. Do NOT try to drill out, or use an easy out. You will bugger up the remaining threads. I believe it is a M8 x 1.25 x 4". Use a tooth pick and measure carefully how far below the block the remaining piece is down. That bolt may even be an M6 which means it's only about a 1/4" diameter. The "old school" rule of thumb is that for full bolt strength, a 1/2" diameter bolt must go in 1/2". A 1/4" diameter bolt only meeds to go into 1/4" of threads, but this is a bare minimum. This bolt is too small anyway so don't even consider going smaller.
I will almost guarantee you that if you had any way to reach that broken stud without damaging the existing threads, it would twist out by hand. Problem is no way to get to it. You could try a tiny dab of super glue or even a metal cement as if you dab it only on the remaining stud it wont spread out and clog threads, but stud may back out with that little bit of grip. Measure accurately how far down broken piece is and let me know. Take a new 4" bolt and thread two or three nuts onto it and then cut off or grind off carefully the same amount from a full-size bolt. Use a file and chamfer the end of the bolt slightly so starter threads are good. Then back off the three nuts you put on the bolt and they will clean up the bolt sufficiently. If you are broken 1/4" or more down, a sorter bolt will be ok. Use thread locker(blue).
P.S. *if* you decide to try and reverse drill it out, use the smallest drill you can....say a 3-4 mm reverse drill and insert a piece of stainless steel shim stock rolled into a tube small enough to fit inside the hole to protect the threads. Let's say you buy a piece of .005" stainless steel shim stock. Cut it about an inch wide and roll it around your drill bit and stick the whole mess in the hole. The stainless will resist the drill flutes tearing up the hole and if the reverse drill is centered carefully, as the broken stud backs out, so will the shim stock and the whole mess will be on the floor. Use a stainless bolt and torque to the recommended 25nm (I believe). Natural tendency is to tighten more, but if you use a tad of hi-temp gasket maker it will seal just fine.
Old 10-08-2011, 09:32 AM
ELCID86 ELCID86 is offline
Mein Auto: 330i ZHP
Well, it happened to me too. I thought it was the torque wrench releasing, but it was actually the aluminum bolts/studs breaking. I was was able to back them out with a pair of Vice Grips-thankfully there was enough room to grab the remaining stub. 540iman do you know the size or part number of the bolt you replaced them with?
After more research, it appears the OEM numbers are 07129901921 or M6X30-8.8-ZNS. Anyone know of alternate sources?
Old 10-08-2011, 01:21 PM
540iman's Avatar
resident, old fart
order #6 X 30MM and #6 x 100MM for the long one you broke. Get several extra 100MM lonf bolts from Fastenal. No one will have in stock.
Old 10-22-2011, 02:21 PM
Mein Auto: 330i ZHP
No luck with Fastenal. They only had the M6 in 1 meter that would have to be cut at a local shop (for a fee). I just ordered the OEM ones from ECSTuning. All ist gut!
Old 10-22-2011, 03:16 PM
540iman's Avatar
resident, old fart
I bought from Fastenal so either you did not ask for the right thing or you did not order in chrome. They sure do have them, but as I told you...most stores the salesman will have to get off his ass and look as they won't stock these on the shelf. The OEMs are aluminum so just be careful. If you don't use aluminum, use stainless steel (much preferrerd)
Old 10-25-2011, 05:07 AM
Mein Auto: 330i ZHP
I did not ask about chrome, but the two different people I spoke with seemed knowledgeable and could not find the 30mm size in any metal. I do see M6-1.0x32mm Mild Steel in lots of 2500 units (@$3625) Fastenal Part No. (SKU): 11110835. The 1M Stainless is Fastenal Part No. (SKU): MR2551000A20000.
Perhaps if you find it you can post the part number for others here.
Old 10-25-2011, 05:53 AM
540iman's Avatar
resident, old fart
I just called the local Fastenal store and bought like 8 of the 30mm and 6 of the 100mm so I would have some extras. I probably have what you need, but by the time I look and mail, you should have. Toyota stocks them I believe for some application in one of their cars, but to get them to look up a part# is like pulling teeth. You don't need to buy a gross or a thousand. I bought pcs. I wanted and had them shipped to my house. Was under $15.
You can get the 30mm anywhere-Menards, Lowes. It was the 100mm I broke and so that's the one I really needed. Once they said they had the 100mm in stainless, I just went ahead and got the 30s to make sure I had no rust issues. I'm sorry, but the desk guy looked up the number for me. You should check hex head, cap heads, etc. I got hex heads like oem, but be willing to use a cap head if necessary. Will work just the same. Use a washer if you are concerned.
Old 10-25-2011, 06:19 AM
Mein Auto: 330i ZHP
Post the part number. Lowe's and Home Depot do not carry them here in VA (I checked a MD location also).
Old 10-25-2011, 02:07 PM
Burning2nd's Avatar
Under the lift arms
Pitch and thread... FFs
15486372<-----
Old 11-06-2012, 06:53 PM
marlinspike marlinspike is offline
Mein Auto: 540i
So what's the solution for the guy who is left with a piece of bolt broken way down in there? He seems to have disappeared. I'm in that same boat.
Old 11-07-2012, 05:57 AM
Mein Auto: 330i ZHP
I know there are tools for backing out broken bolts. Do you have a Harbor Freight http://www.harborfreight.com/ near you? Search some here too. good luck.
Old 11-07-2012, 06:08 AM
Mein Auto: 540i
WWay too deep for any of those tools. I managed to get it using shoe go on the broken end of the bolt to unscrew the piece broken inside.
Old 11-07-2012, 07:08 AM
540iman's Avatar
resident, old fart
Huh???
broken bolt, engine block, water pump
