Again, more stuff with this car.
Here's what happened today. After having the vavle covers replaced and seeing all the sludge I got, I thought about cutting my losses on this car and trade it in or selling it. I stopped off at CarMax. Ya, I know, what was I thinking. They gave us a good price on a car a few years ago and I have been happy with the Jeep my wife bought from them as well, so I thought I would give them another try. We got a price for the car (what a joke) and went to get something to eat. We get home after they had closed, I parked the car in the drive way, turned it off, went out later to put it in the garage and when I started it the BRAKE, ABS, and DSC light came on. I took it out for a drive and the speedometer and odometer do not work. Could these guys at carmax screwed up something when they inspected it or is it just a coincidence? Also, I found Bluebee's DIY on this. Great post. Anyway how do I test the 4 wheel sensor circuits from the ABS module connector? Could my problem be the ABS module? Sorry still new and learning as I go. Any advice would be great.
The left rear wheel speed sensor is responsible for the speedometer/odometer.
2003 530i (Sport Package) Build Date: 02/03 Titanium Gray over Black Shadowline Trim 5-Speed Manual Transmission Zeckhausen Modified CDV Dinan Upgrades: High Flow Throttle Body, CAI, Stage 3 Software, and Free Flow Exhaust. Horsepower: some is good, more is better, TOO MUCH is just right! "If everything seems under control, you're just not going fast enough." ~ Mario Andretti "What’s behind you doesn’t matter." ~ Enzo Ferrari |
What was the price they gave you? They couldnt have messed anything up, mine did the same thing out of nowhere. Sensors usually go before the module.
Definitely use Bluebee's DIY to check the sensors at the connector. The check is very simple and quick. I would not just start replacing any parts without checking it first.
If you decide to keep the car you should consider changing the engine oil and filter more often and use a good quality synthetic oil. Personally, I would stay away from the engine cleaners that claim to remove sludge if you're considering that method...sometimes that can do more harm than good. The sludge probably occurred due to the PO not maintaining it properly. Sludge, while certainly not a good thing, does not necessarily mean a catastrophic failure is in your future. I'm assuming you are not using coolant and have no oil pressure warnings? Good luck and I'm sure you can get some sound advise/help in here if if you can't get the issue sorted out. |
Module Master fixes them for $300. |
I just saw the pics of your engine sludge from one of your previous posts....that's a bunch of sludge.
I still would not use any of the "sludge cleaners" if it were mine. Too great a possibility of sludge chunks clogging the oil pump pick-up that will cause an engine failure. If you are not having any problems, i.e. warning lights, smoking, using coolant, etc., I would use a good synthetic oil and change it along with the filter at reduced change intervals. Sludge typically forms in the "cooler" parts of an engine. If I'm not mistaken, the oil pan can be easily removed on an 8? Remove it and take a look. |
The trifecta happens to almost all of us at some point.
In most cases, either a (single) wheel speed sensor is bad or a badly tack-welded steel (power?) wire lifted off its gold bondpad inside the ABS control module. In all cases, as explained in the DIY you referenced, the first step is a ten-minute test of the four wheel speed sensors with a digital multimeter (DMM). If the wheel speed sensors are known to be good, then almost everyone simply has it rebuilt by BBA/MM/ATE. Cost is from $150 (which is what I paid, including $25 shipping) to $300 (depends on whom you choose to rebuild it). Quote:
Pray tell (so we improve it) - what is missing from the description below? Quote:
You know I had the same thing (the three lights on + speedometer not working) happen to my wife's 2000 540 after I had it up to replace the water pump. In Bluebee's DYI which is linked in her post here among the first things to try is slowly turn the steering wheel from far left to right. I assume this will reset the steering angle sensor and since I did rotate the steering wheel while the car was up with engine off to get an easier access for the jack I thought I might have done something to throw off the sensor and I'd give it a try. Unbelievably it has been several weeks since and she has not had the lights come on again. I am still not completely convinced that this was the fix as my reasoning tells me that things seldom get repaired by just turning the steering wheel but this will be the easiest thing to try. They might have turned the wheel with the car up as I did. Again, it might just be my imagination just trying to help.
Thanks for the replies. I stopped by local Autozone and had them check for error codes on the OBD but no code errors showed up. I'm going to pick up a new DMM tomorrow. The one I have is about 15 years old and it is a little out of date. Besides I don't think I have used since I purchased it and I really don't trust it.
I hope I can follow Bluebees write up and found out what is going on.
http://www.eaceuroparts.com/catalog/product/426
When you determine your module is bad give me a call. |
I need of some more guidance on testing the ABS module connector . First off I grabbed the wrong wire at Lowes. Picked some regular galvanized 20 AWG not electrical, go figure. I know it will carry a current so I tried it anyway. With the meter set to diode pins 13,19 gave a reading that would fluctuate all others stayed at 1. Any idea what's bad?
The car got mad that you went to get a # on selling it!
All my cars had some weird failures as soon as i put up a "for sale" sign or listed them online for sale. lol scary.
Andreas Queens NY BMWCCA# 186796 86 325es (wrecked by careless driver) 87 325 300k (project for life) aka 1BADETA/Christine 00 540is 6spd 202k (daily driver) |
Pin 19 is feeding the engine control module and Pin 13 feeds the sensor. I think with the "1" readings, you're not making a connection with the test ports.....try a "jumbo" paper clip....worked well for me.
The best advice ANYONE can give you is to learn how to use the search function. How many times are we going to have to go over this...
It's really hard for us to 'guess' (especially since I didn't experience major problems reading so I never learned the troubleshooting steps); but, taking a long shot stab at it ...
Thinking back on that, I may not have been right (I don't really know at this point). Actually, I 'still' have the wires so I could measure them again. Anyway, we should ask anyone 'else' who tested this successfully what AWG they used to be sure of that 20 AWG that I quoted loooong ago (in post #48 of this thread). |
Couple of things...........
1. The new DMM I bought was bad. Took it back and exchanged it for a different one, also bad. Got a third one and guess what, third time is a charm. 2. Used paper clips instead of wire. 3. ABS-connector pins 13,29 read 500-600mV. Left rear wheel sensor bad. That's my guess. Going to replace it tomorrow. Found it locally for $72. Will let you know how it worked out.
Running a cheap transmission Fluid in your engine is a good, gentle sludge cleaner. i would run about a quart of ATF for about 30 min before changing my oil. ATF is rich in detergents, but like Fleetman said, the concetrated engine flush fluids may do all too good of a job, and remove large chunks of sludge debris and let them clogg oil gallies and plug the pump pickup screen.
you go Loganwolf! It sounds as if you've probably found your problem and the speed sensor will probably take care of it.
As for the sludge, as long as you're not having a problem with warning lights, smoking and etc., I would simply keep changing the oil and filter regularly....in my experiences, sludge forms in the cooler spots in the engine and doesn't necessarily migrate to other areas UNLESS you use a cleaner. Yes, a BMW can be a challenge but there's nothing on our cars that cannot be repaired by using the assistance of others in here. I've gotten frustrated with the "search" myself at times (soooo much reading) but it always gives me an answer. Use the search when possible and if you still haven't found your answer or need a clarification.....ask away young grasshopper! |
). I'm guessing it was a mixture of water, oil and coolant. I plan on changing the oil in about 500 miles. Then again at a 1000 without Seafoam and see what I got. I did check the oil filter for debris and so far just some small stuff, no big chuncks.
SeaFoam intake cleaner or oil treatment (do they make an oil treatment).
If it is Seafoam that you induce into your motor via a vacuum line, then it is not doing anything but cleaning out your intake manifold and the tops of the intake valves. |
Just got done looking at the sensors. Oh what fun.....
Here is what I found. When I purchased the car, the previous owner had the breaks and rotors done for me. This was quite generous I thought until I took a good look at things. Some how the sensors on all four tires are hanging down loose just a little bit. They are close to the rotors. They all look burnt to a crisp. I called the previous owner and he sent me to a break shop (pre-paid). They looked it over. He then showed me what was wrong and how the guy who did the breaks did not use what looked like a heavy coat hanger cut in half to hold the sensor in place when the pads and rotors where put back on. This guy had two other cars in his shop with the same problem, a Lexus and another BMW. He gave me a reasonable quote of $450(about $100 for each sensor and $75 for labor). He called the previous owner and told him the price. He thought it over and after seeing the pictures of the sludge, which he says he was unaware of, he decided apologetically to just give me my money back on the car or fix the sensors. Somehow I feel lucky but I'm not sure how. Great guy and I love the car, I also have grown attached to it but the sludge is so bad. He gave me a few days to decide. So I have an appointment for Friday to have the sensors fixed or to take the car back to him.
Wait. So you just bought this car and were going to trade it in? I would get your money back and find a 5 you are more comfortable with.
![]() 2000 528itM/5 1996 M3 |
The first comment is that I'm incredulous that a 'mechanic' (a) had to even remove the sensors (as they're generally not removed during a brake job) and (b) that they could possibly put them back with a coat hanger. One set of sensors has a single bolt holding it in (how hard could 'that' be to replace?), while the other axle has two bolts on each sensor. It's not a difficult job by any means to bolt back in (it might be difficult to remove, but that's what mechanics do every day). My second comment, I hesitate to say, well ... because I don't wish to offend ... and, I generally let a few typos slip ... but ... ummm ... you wrote it multiple times ... so ... ummm, I'll whisper this gently ... it's brake, not break. Back on topic ... please post a picture of the coat-hanger sensors as I've never seen a brake job done that way so I, for one, am intrigued by what is there. |
#25
I would get the money back, Check out craigslist.com, there are always BMW 5 series for sale. Find one you may like, take to your mechanic, have him do a thorough inspection.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
