Old 05-04-2011, 11:22 AM
Turbotoma Turbotoma is offline
Mein Auto: 2004 745li individual
272c & 272d fault codes???
Hi guys
Sorry 2be a pest just you guys have been so helpful with my problems hopefully I can get some good advice again.
Had car on my mates computer and these fault codes came up
272c
272d only these 2 came up and I was wondering if these faults make the car run with a intermittent bad idle? Sometimes the idle of the car jumps up n down and I wondered if this could be the course or something more sinister that won't show up on a diagnostic machine.
Thanks again guys
Sent from my Desire HD using Bimmer App
Old 05-04-2011, 01:04 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Check this thread for fault codes posted by Wilson
http://www.bimmerfest.com/forums/sho...d.php?t=432282
These are fuel mixture codes which can definitely be a reason for idle surges. There could be a number of things that can affect the air, spark, fuel mixture that can throw a code like this. The common culprits are :
Vacuum leaks
Bad Mass air flow sensor
Bad oxygen sensor
Bad fuel injectors
Clogged fuel filter
Crankcase ventilation valves.
I am currently troubleshooting a similar problem which I have yet to nail down. If you are not handy and dont have diagnostic tools you need to have the car properly diagnosed. Alot of things here that can cost a bit of money if you just start throwing parts blindly at this problem.
Old 11-19-2016, 09:43 AM
nilsnilsen nilsnilsen is offline
Mein Auto: BMW 735i
Hello! Did u ever resolve this issiue? I have the same problem, and over the last year ive changed maf, fuel filter and cvv. I have added cleaner for the injectors and had my mechanic to perform a smoketest. My o2 sensors, which i belive is the same as lambda are working as they should.
Old 11-21-2016, 03:33 PM
Mein Auto: BMW 735i
No one got a suggestion? Something to push me into a new direction
