Old 05-06-2011, 04:45 PM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: 2011 328 XDrive
Heated Seats
I have problem with my driver side heated seat, I turn it on....the 3 green lights light up... Then after1-2 seconds they turn off. Keep doing this and it does the same thing. It has been a couple of months and I forgot about it. So I thought I would reach out and see if anyone else has the same problem and/ or know how to fix this. Thanks all
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 05-06-2011, 06:31 PM
Herbalizer Herbalizer is offline
Mein Auto: 2004 BMW 645ci
Check your battery, if it does not have enough juice, it will shut down your heated seats to save power (does it happen on the passenger side?)
Old 05-06-2011, 07:31 PM
Nope, passenger side works just fine
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 05-08-2011, 12:17 AM
petros2r's Avatar
petros2r petros2r is offline
Ducati fills my BMW's gap
Mein Auto: '05 645ci
It could be shorted-out. Smell underneath when you turn it on?
2005 Ducati Monster S2R 800
2005 BMW 645ci Cabriolet - SOLD
2013 Lexus RX 350 F Sport
Old 11-03-2011, 05:48 AM
I don't smell anything under the seat, all fuses are good. Cold weather is coming and I still have no resolution. Anyone?
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-03-2011, 06:09 AM
2modfast 2modfast is offline
Mein Auto: Cars
The lights are turning off, but do the seats warm up?
Old 11-03-2011, 06:54 AM
Push button. Lights go on for 3 seconds then turn off. Seat not heating up???? Who knows
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-03-2011, 08:18 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Perhaps you should swap the switch from left to right to determine if that is your problem? I am not sure if there is a relay involved in this, but if it were a fuse you would think it would not work at all.
There have been folks who had heated seat failures in the opposite direction...the seats would overheat and burn the leather, and possibly them. So this indicates that each seat has some type of control unit somewhere. I just don't know where. There are some on here that have the Electrical Diagrams and might be able to advise you.
Good luck in keeping your rear warm!
Old 11-03-2011, 08:25 AM
Thanks again for the reply, I will give it a shot, maybe there is a plug under the seat that came loose or disconnected but then again when I had my z4 I took the seats out to have the carpets cleaned I had a dash light that came on. I will dig further into this and update. Thanks again
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-03-2011, 10:57 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Took a look at the WDS (BMW wiring diagrams) and here is an excerpt from the seat heating description:
Fault monitoring
The electronic seat heating control system monitors the temperature sensor and heating mats for faults. Detected faults are stored in the fault code memory of the centre console switch centre.
The following faults can be recognized:
Short-circuit or line break
Short-circuit or line break of temperature sensors
Break in heating mats
If a break or short occurs at the temperature sensor, the seat heating is switched off in order to prevent overheating. The function LEDs are switched off.
All other faults described in the full document mention the button LEDs remain on during the fault, so it appears you have short or break in the temp sensor.
The error can probably be read if you do a scan of error codes. The codes might help pinpoint the problem.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-04-2011, 04:16 AM
elandan elandan is offline
I Need to Speed
Mein Auto: 2011 Titanium Silver 750i
Once again, Yorgi is the best! What would we do without you....
2011 Titanium Silver 750i M Sport
My daily driver
Old 11-04-2011, 12:48 PM
twenspirited twenspirited is offline
Mein Auto: '04 645 cic
Weird thing, I'm having the same issue! Driver seat push will give the 3 lights but will disappear after 2-3 seconds. Seats does not heat up.
Old 04-11-2012, 02:58 PM
bdz bdz is offline
Mein Auto: 2005 BMW 645ci
drivers side heated seat
Hi, I have the same issue with my 2005 645ci, push the drivers side heated seat button, 3 lights flash but does not turn on. Passenger side is working. Any resolution here?
Old 04-14-2012, 03:25 PM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
Move to Vegas!! The seats heat up to around 140 degrees just fine without even turning it on
Old 10-12-2012, 04:03 AM
mfellman mfellman is offline
Mein Auto: 2008 M3 convertible
x5 intermittent heated seats
same prob. lights come on...seats heat up...then go off...
dealer said...new seat...$1200.
now what?
Old 10-13-2012, 12:45 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
The reason it's your driver seat that's acting up is because its the most used seat.
Old 03-21-2013, 06:25 AM
Steven630 Steven630 is offline
Mein Auto: 6301 sport
Heated seat problem
Hi just thought i would add to this, i have recently purchased 6301 sport privately, great car with full history. however after a few months of ownership i noticed that on the back of the driver seat seamed to heat, as this was warm enought i did not think musch about it, until a few days ago a burnt hole has appeared on the bolster edge of the base seat ( see pic ) couple of questions.
1 does the base work independly to the seat back
2. how difficult is this to replace ?
3. Any one seen this before
Old 03-21-2013, 07:33 AM
colink colink is offline
Mein Auto: 2004 645Ci Convertible
Search the forum - this seems to be a known problem and in the US at least, members say that BMW is so concerned about the liability they pay for the repair even if the car is out of warranty. I have no personal experience of this (yet).
Old 03-21-2013, 05:41 PM
Stalag Stalag is offline
Mein Auto: 530i
So, I have a different heated seat inquiry. I have a 645ci and there are no heated seats. Does anyone know the process and rough cost? Thanks
Old 03-22-2013, 08:23 PM
BeastMW BeastMW is offline
Mein Auto: 2005 BMW 645 Coupe
Thats what happened to me before it shorted and burned a hole through my seat.
2005 645, 22in Giavanna's, Stratus Grey Metallic/Black int., custom quad exhaust, blue angel eyes, 30% tint
Old 03-24-2013, 04:43 AM
Hi colink
Thanks for the heads up on the BMW concern. I can see it being a serious Heath issue. Think I will write to BMW uk.
Regards Steven.
Old 05-06-2013, 04:34 PM
Mattman645 Mattman645 is offline
Mein Auto: 645ci cabriolet
Hi Steven - I emailed BMW HQ in Bracknell last week with the same issue on my 04 645 - small hole burnt in lower right side seat back.
Tried my local dealer who refused to do anything as car is too old.
Sent a pic of damage with my email, not got a reply yet so will give it a couple of days and send a chaser.
If you get any response, post it up!
Old 05-08-2013, 04:35 AM
OK - got a reply back from BMW UK - doesn't look like they are willing to do much
"Thank you for your email dated May 2, 2013. I am sorry to learn that you have encountered an issue with the heated driver’s seat of your BMW 645Ci. I can certainly appreciate your concern, especially as your wife suffered a burn as a result.
I acknowledge that you have located information on the Internet, which has led you to believe that there is an issue with the heating elements used in BMWs. However, I can assure you that this is not the case. BMW collates failure reports and part orders from our network of appointed dealerships around the world, which offer us a much more factual insight in to potential situation such as this. Taking these information sources in to account, I can confirm that there is no evidence to suggest that failure of the driver’s seat heating element is an inherent defect with our vehicles.
I am concerned to note that the Service Technicians at Wood in Hampshire, refused to inspect your vehicle. I would like to reassure you that BMW UK expects our appointed dealerships to diagnose any issue that is presented to them by our customers, irrespective of the vehicle’s service history.
At this juncture, I would recommend that you allow an alternative BMW Approved Dealership to investigate the reason behind this failure. Should the advisors deem it necessary, they can contact BMW UK and request that we assess a claim for financial assistance towards the repair costs. However, please note that as your vehicle has no valid warranty policy in place, you will be liable for the cost of repair.
You can locate the contact details of all appointed dealerships in your local area by visiting www.bmw.co.uk and clicking on the ‘Find a dealer’ locator, situated along the top of the homepage."
So guess i'll get it booked in for an outstanding recall notice, and get them to look at the damage and see what happens!
Old 11-10-2014, 01:10 PM
girlygirl girlygirl is offline
Mein Auto: 2005 645 Ci convertible
Heated Seat Issue
Hello all - this is my first post! Just this past weekend I also was burned by the driver's side heated seat of my 2005 645ci convertible. There is a small burn hole on the lower front left side of my seat. Of course the expensive warranty package that I purchased (April 2013) does not cover heated seats. I saw that you emailed BMW so I just did the same thing though I don't expect much help. There is obviously some defect since it has happened to others.
Old 12-27-2014, 11:32 PM
stnmartin stnmartin is offline
Mein Auto: 645ci
645ci heated seat retrofit
Hi. Im Martin. I am about to fit oem seat heating into my 2004 645ci. Got the switch consol fitted, got the seat heater elements fitted and now struggling with the wiring. I've done days of research on the net but i cant find a solution for my case. As i seen everybody runs wires from under the seat to the switches and then to the fuse panel bla bla... my case is: all of the slots have wires fitted behind the control /switc center unit, when i fitted this unit it was light up without any issue so i think the fuse and the wiring is exist in my car but down under the seat the yellow plug doesnt have the 3 wires fitted for the seat heating connections.. strange. So i just would like to know if there is a module or connection point under the carpet or which colour of wires do i have to extend from the switch unit to this yellow plug. I seen lots of diagrams but i can lost myself in that kind of drawings. Thank you for any help!
