E46 (1999 - 2006)
Old 05-08-2011, 11:23 AM
ckberry ckberry is offline
Mein Auto: 2002 330i Sedan
Wind Noise, Window too High?
Got my first E46 a few months ago and just started to experience extreme wind noise from the driver side window (This is a sedan, not a coupe). I figured out why: When I roll the window all the way up, it presses against the seal at the top of the door in such a way that it pushes the glass and the seal outward from the door so that the rubber seal sticks out and catches the wind. I thought that maybe the window is going too high, but this doesn't see like something the Germans would let happen. Please help a newbie!
2002 330i Sedan
Old 05-08-2011, 06:08 PM
theruined theruined is offline
Cross Drilled Huh?
Mein Auto: 2001 325i 5-Speed
I had this problem and realized the previous owner had removed the external trim and moved it down to hide some scuffs on the lower portion of the trim closest to the hood...suspicious, but it did take me a while to figure that one out...check that your external trim lines up on both sides of the car, if that's not the problem you may want to take it to a shop (with an air bag sensor bypass kit) and have them adjust the window regulator...
gl man
The Black Butte Straight from Germany
'01's Finest
Old 05-10-2011, 07:15 AM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
My window has a slight whistle if I don't back it down a tiny (tiny!) bit after auto-up. Now it's just habit...
Old 05-10-2011, 06:05 PM
Solved
Figured it out. The window wasn't squared at the top which allowed it to push outside the track on the rear side of the window. It just needed adjusting, which is pretty simple:
Disconnect negative terminal
Remove door panel and vapor barrier being careful with the airbag
Loosen both bolts on the rear window guide rail
Reconnect battery
Roll window all the way down (push it down square if necessary)
Tighten both guide rail bolts
Thats it.
door, noise, seal, wind, window
