E46 (1999 - 2006)
Old 05-09-2011, 07:35 PM
tblt44 tblt44 is offline
Mein Auto: vette
What rear diff oil to use
2005 325i
The manual says 75w-90.It does not say synthetic or not.
I use Mobil 1 full synthetic in my trucks.Would this be ok for the 325i.
Or would a synthetic blend be better ?
Another question, do these cars have a posi or limited slip diff ?
thanks all
Old 05-09-2011, 08:12 PM
RSPDiver's Avatar
RSPDiver RSPDiver is offline
Ich bin ein Bimmerer
Mein Auto: 04 ZHP/4
Synthetic, for sure: less likely to break down over time and become acidic. I used Royal Purple (because the other favorite brand wasn't available) and it is doing well. And only the ///M cars come stock with LSDs.
Old 05-09-2011, 09:52 PM
oilsschmoils oilsschmoils is offline
Banned
Mein Auto: BMW
Redline 75W90.
Old 05-10-2011, 07:18 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Originally Posted by oilsschmoils View Post
redline 75w90.
+1
Old 05-10-2011, 07:21 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
redline 75w90.
1+
PT
___________________________________
Old 05-10-2011, 08:54 AM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
Mobil1 75w-90
Old 05-10-2011, 08:58 AM
Kubs Kubs is offline
Mein Auto: 2003 330 Ci
I use Amsoil 75W90 rear gear oil. It works great and actually helped my fuel mileage.
http://www.amsoil.com/storefront/svg.aspx?zo=1934716
I also would recommend the hand pump that Amsoil sells
http://www.amsoil.com/storefront/g2039.aspx?zo=1934716
I changed my trans and diff oil in less than 1/2 hour. The pump makes filling the diff and trans so much easier.
Old 05-10-2011, 10:37 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If the E46 is similar to the E39 (we share the M54 engine but I'm not sure about the differential), then this list may help:
- BMW E39 fluid summary printout for your glovebox (1)
Here's a related excerpt from post #16:
- Differential (conventional, i.e., non-limited-slip E39s): The Bentleys specify "BMW SAF-XO synthetic final drive gear oil" which doesn't exist (it's Castrol). The Bentleys don't specify the weight (it's SAE 75W-90); and the Bentleys don't specify the quality (it's API GL-5 hypoid gear oil). Given that, suitable replacements are Amsoil Synthetic Manual Transmission Fluid (MTF) API 75W90,Mobil1, Royal Purple Max-Gear, & Redline SAE 75W90 API GL-5 synthetic gear oils. Unfortunately, there's no way to tell which of the three (3) different differentials you have w/o looking at the numbers molded into the metal. Bentley page 020-11 & 020-26 & 331-6. [Volume: Type G=1.7 quarts, Type 188 Compact=1.1 quarts, Type 220/215 Compact=1.5 quarts.] Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles).
- Differential (limited-slip E39s, such as the M5): BMW SAF-XJ API GL-5 SAE 75W-140 synthetic hypoid final-drive gear oil (aka Castrol SAF-XJ). This requirement is not listed in the Bentley manual; it is gleaned from the Castrol literature and from what is stated about the M5 in this thread below (please correct if necessary). Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles).
Old 05-10-2011, 10:40 AM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Redline 75W90.
One more +1
Old 05-10-2011, 11:24 AM
mrblorry's Avatar
mrblorry mrblorry is offline
No User Serviceable Parts
Mein Auto: '04 545i, Schaltgetriebe
Redline 75W90.
I just poured this in my diff this past weekend.
-Steve
Old 05-10-2011, 01:33 PM
spencers's Avatar
spencers spencers is offline
Mein Auto: 2006 330i
I use Redline 75w90
Old 05-10-2011, 03:35 PM
Mein Auto: vette
Wow everyone uses redline.
I don't know if I have that local.
I do have royal purple and Mobil 1,I will have to look for redline
Old 05-10-2011, 03:41 PM
You don't. Mobil1 is as good as any other synthetic GL-5 75w90 gear oil.
Old 05-10-2011, 03:47 PM
Scottji's Avatar
I ordered redline tranny and diff fluids from Amazon
Old 05-10-2011, 05:51 PM
Mein Auto: vette
I use Mobile 1 gear oil and motor oil in my trucks,I just didn't know about theses cars.
I will probley go with Mobil 1 than.
I guess if I go with Mobil 1 engine oil I need to use 0w-40 also to meet a BMW approved oil.
Old 05-10-2011, 07:37 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Yes, if you read the fine print on the bottle you will see that it is BMW LL01 certified. I'm running with it now.
Worth noting, though. The Official Oil that the dealers use and sell over here is Castrol Syntec 5w40. Don't know if it is cause Mobil is a bit more fluid, but the engine has required about a pint to top up in the change interval, whereas with the Castrol it was not necessary. Over here, synthetics are extremely difficult to come by, BMW compatibles even more so, so those are the only two choices available.
2006 325Ci
Old 05-10-2011, 09:41 PM
Banned
Mein Auto: BMW
Nope! One is a group IV PAO and one is a Group V POE, and that definitely isn't the same.
Old 05-10-2011, 09:53 PM
Links?
Old 05-11-2011, 02:38 AM
Banned
Mein Auto: BMW
Go to Mobil and Redline web sites.
Old 05-11-2011, 06:31 AM
I did. No such info there. So, links?
Old 05-11-2011, 07:16 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
Here is a link to oils BMW says to use.
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
If you use Mobile 1 you should use the "European Car Formula 0W-40", (see attached picture).
PT
Old 05-11-2011, 07:58 AM
Now read the topic's title.
Old 05-11-2011, 08:08 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
tblt44
Now read the rest of the thread...we got side tracked.
PT
Old 05-11-2011, 08:12 AM
Just quote the offtopic you are answering to.
Old 05-11-2011, 08:16 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
No
PT
