Old 05-13-2011, 03:00 PM
OCSeth OCSeth is offline
Mein Auto: BMW 740il 2001
01 740il Navigation screen
Hi,
I have a BMW 740il 2001 year model (e38).
I have recently changed my battery and after that the display screen (navigation screen) on the board went blank that is it has a (blue) light behind but no visual and the radio even cuts off in 2-3 mins and I have to turn off the radio and the restart it. When I saw the navigation system in the trunk the cd in it was coming out automatically in a few mins. The screen under the speedometer is working just fine and displays everything(that is the one in front of the steering wheel). I would like to understand what is wrong with it and what should I do to fix it. Even I am a student and so I would like to try all the cheap options first. I dont want to go to the dealer.
Old 05-13-2011, 03:03 PM
PoolBoy's Avatar
PoolBoy PoolBoy is offline
live like no one else
Mein Auto: 2007 BMW 750LI
Wish I could help but no idea. Try posting in the 2001 forum. This is 02-08
Sent from my DROIDX using Bimmer App
2007 750 LI
Yes its my style and those ARE 20's
Old 05-13-2011, 04:19 PM
BMW 740il 2001 (e38)model Screen on the board
Hi,
I have recently changed my battery and after that the display screen (navigation screen) on the board went blank that is it has a (blue) light behind but no visual and the radio even cuts off in 2-3 mins and I have to turn off the radio and the restart it. When I saw the navigation system in the trunk the cd in it was coming out automatically in a few mins. The screen under the speedometer is working just fine and displays everything(that is the one in front of the steering wheel). I would like to understand what is wrong with it and what should I do to fix it. Even I am a student and so I would like to try all the cheap options first. I dont want to go to the dealer. Even when I was jump starting the car I might have used the reverse terminals for jump start, is the fuse gone? where can I check the fuse and where can I get the cheapest parts?
Old 05-14-2011, 12:44 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
There is a very good chance you accidentally fried your Nav unit. The Nav needs it's red LED light to go out (cycle down) before power is removed from it (via disconnecting the battery or pulling the power cable from the Nav). Not letting the red LED to go out first can cause the Nav to die.
The easiest way to determine that this is your problem (sure sounds like it is) is to borrow a Nav from a friend & see if his Nav works in your car & your Nav has the same problem you're having now in his car.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 05-25-2011, 05:45 PM
need a send nav to check
i would like some help on it as i dont have a friend who owns a bmw and so if in south california would be able to help.
Old 05-25-2011, 05:48 PM
Bell528i's Avatar
Bell528i Bell528i is offline
Ich bin ein Berliner
Mein Auto: 2001 740iL
This is your car's way of telling you to upgrade to an MK4 navigation computer.
Der einzig wahre Fehler ist, wenn Sie versuchen zu stoppen!
Old 05-25-2011, 05:53 PM
hey sealbeach740 can u help me try the change with ur nav i can come down to your place or near by
Old 05-25-2011, 06:59 PM
Sure. It should only take 5 minutes.
Email me & we can try to set it up.
Old 05-25-2011, 07:27 PM
Thanks for your understanding. I am free tomorrow in the day if you want to do it then please let me know or we can do any time on friday...
Old 05-26-2011, 10:26 AM
Email sent...... we should take this offline.
HTML code is Off
