Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-13-2011, 05:38 PM
cmartin7x cmartin7x is offline
Mein Auto: bmw 535i
fuel line question
with the 535i i just bought, its not running right. i pulled the fuel line off of the fuel pressure regulator thats right on top of the front of the engine. when i turned the key forward no fuel came out. when i cranked it over fuel flows out of the fuel pressure regulator instead of the fuel line. did someone cross these lines sometime in the past? or am i missing something
Old 05-14-2011, 08:49 AM
catso's Avatar
catso catso is offline
catso
Your car has the fuel enter the rail at the rear and return to the tank througt the pressure regulator. You really need to get yourself a Bentley's manual to diagnose your problems.
![/I][/FONT]
Old 06-08-2011, 06:54 AM
nowayray nowayray is offline
Mein Auto: 88 535i
i have the same when does the fuel get regulated? or does it just flow back to the tank ? i tried to apply vac to the top port no difference. the car still seems to run out of gas
Old 07-06-2011, 07:02 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
The regulator controls the pressure of the fuel at the injectors by varying the amount of fuel that it lets return to the tank. If the fuel comes out of the top line (smaller) then your diaphragm is bad and you need a new FPR. By the way, it will only pump fuel when cranking and for 2 seconds if the engine doesn't run (safety).
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
