E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
86 325 Driver Door Issue
Another question:
The driver side door was making a popping sound when I would open and close it. The popping sound has stopped but now I can't open the door all the way. It seems to be getting hung up. Any help is much appreciated!!! |
Aloha, When I had this issue with my '89, after getting a suggestion to put on some grease stuff. When I was vacuuming my car the other day, I realized the bolts on the door were loose and I tightened them and fixed the problem. Hope this works for you
The door check strap is probably broken within the door. The strap holds the door open in 2 different positions
Door strap. Just unhook it.
Remove it or replace it! Left just unhooked it can dent the door from the inside.
| Bookmarks |
| Tags |
| 86 325 door |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
