E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Low wierd power
I have an E36 325 without vanos.
The problem is that when I run on regular speed, I can feel power ranges 80-100% can also see it on the economy gauge that fluctuates. i have change air flow meter and oxygen sensor. but i stil got the problem . enginen and transmission have run abourt 280.000 km. i tryed to drive without air flow meter but the problem is stil the same. over 4000 rpms its getting better but when im change to next gear it lossing power again. what could be wrong? |
It could be a lot of things. My first thougt was vacuum leak. I would suggest you look in to that first. Then consider a new fuel filter if you have not changed yours recently.
Hope this gives you a starting point. Also, welcome to the Fest Steve
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
If the spark plugs are old, replace them.
Ignition coils (on top of the spark plugs) age and cause the same kind of poor performance as bad spark plugs. The intake rubber boot can crack and cause poor performance. For me it did and when accelerating, the engine twisted slightly to widen the crack. If there is no difference driving the car with or without the air flow meter, something is wrong. Either another bad AFM or bad wiring to it. |
[QUOTE=granlund;6083126]If the spark plugs are old, replace them.
Ignition coils (on top of the spark plugs) age and cause the same kind of poor performance as bad spark plugs. The intake rubber boot can crack and cause poor performance. For me it did and when accelerating, the engine twisted slightly to widen the crack. QUOTE] I'd also start there
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
I have tjek vakum legs, new lambasonde, another air flow meter. Dont know what to do now, but i find a video with the same problem.
Thanks B |
The power surges that you are experiencing might not be due to the engine or it's installed aftermarket components. With that much clicks in your car (almost 300,000kms!), I would assume that the transmission is already slipping. When was the last time you replaced your ATF and filters? My brother in law had the same "wave like" acceleration before he converted his e36 Auto to a 5 speed Manual.
The good thing is, not all tranny slippage is due to a bad transmission. I would first replace the ATF and the filter and see if the symptoms goes away. I would read THIS to see if the symptoms you were referring to are similar. Hope this helps, please let us know what the outcome is. Good luck! EDIT: Quote:
Mona B. ![]() Last edited by mksu19; 07-07-2011 at 04:52 PM. |
^ +1 that's what it looks like to me for sure.
Do you have a manual or automatic transmission?
Hey guys thanks alot for help. Yesterday i borrowed my fathers TPS e36 316i. At the start i dont really feal a difference. But after i reset my ECU the accelerate was alot better. So i tryed to clean my TPS, and it look like it helps. the economy gauge fluctuates but only abit now, and i dont realy feel it. So monday i will order a new one. did it sound realistic to you guys, that the TPS is bad? anyone tryed the same? Its a manuel gearbox
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
