M5 Wont Start , not sure what to try now. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 05-22-2011, 03:13 PM
Aki2011 Aki2011 is offline
Mein Auto: E39 M5
Unhappy M5 Wont Start , not sure what to try now.
Hi my first Post and really need some advise, I have a 99 E39 M5 that just wont start .
The car was not in use for a few weeks and the Battery went flat, I tried to start it with my booster pack but im concerned i might have flooded it and now it just does not seem to want to catch, i tried to jump start the car but still no luck.
The car tries to start , It sounds like it wants to but just wont ?
My question , what can i do next ,
What i have checked so far.
I checked the plugs they looked quite black and smelt of fuel , I changed the plugs but the car still wont start, I have spark at the plugs ?
I tried to remove the fuel pump fuse to see if the car would start but still no luck ( thinking it might have flooded when i tried to boost start it )
I tried 2 sets of keys and the fault still remains.
Im really lost as what to do ? i think it has been flooded but not sure how to overcome this ? all fuses seem to be ok ?
Please advise if anyone has any suggestions ?
Old 05-24-2011, 12:22 PM
scott0357 scott0357 is offline
Mein Auto: 2003 530i
you probably need a new battery to give the engine a strong cranking. The M5 needs a lot of juice to start the engine. Jump starting may not help unless the jumper cable is super large. In the past, I tried to jump start the M5 from a 2003 530i with a large jumper cable; the engine wouldn't even crank. However, a new battery got the car started.
Old 08-01-2011, 05:17 PM
beewang's Avatar
beewang beewang is offline
Bo-ma-win!
Location: Eugene, OREGON, Home to the Rose Bowl Champion
Send a message via Yahoo to beewang
Mein Auto: S62 E39
The BMW M5 requires a battery that is MUCH more cranking power than the rest of the E39 line. The M5 can NOT be EASILY jump started by normal cars. You would need to have a truck w/ DIESEL engine (i.e. a tow truck) to jump start an E39 M5 with a drained or aged battery.
beewang
m5 e39 bmw start help
