E30 (1982 - 1993)
Old 05-23-2011, 06:42 PM
salsa325 salsa325 is offline
Mein Auto: 1987 325 manual
WINDOWS WONT WORK!!!!!! please help...
ok so i swapped starters and changed the master cyclinder in my 90ix..now windows won't go up or down...here are the vitals...they worked in the morning then after starter job then didnt at end of day...also...no light in the up/down window switches...also..no voltage across the 17 fuse...also changed key tumbler a while ago...jumped circuit breaker thingy by gearshift still nothing...is there a hidden relay? please help...driving without windows is miserable!!!
Old 05-23-2011, 07:03 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Did you mistakenly press the window lock button? On some cars it's above the radio / OBC and on some it's on the console.
I Timothy 2:1-2
Old 05-23-2011, 07:29 PM
my lock is by the gearshift...also..that wouldnt affect the backlighting for the up/down arrows...would it?
Old 05-25-2011, 07:21 AM
old carnut old carnut is offline
old car nut
Mein Auto: 1986 325ES STICK
I'm told the unloader wiring on the starter can cause this or the starter itself can be faulty. Do a search or bimmerforum.com. A recent post discussed this.
Old 05-25-2011, 12:55 PM
e^2 e^2 is offline
Mein Auto: '84 325e, '00 323i
Ground?
Old 05-29-2011, 07:56 AM
old car nut
I presume its fixed? Posting what you did to fix it helps us all.
