rusty brakes and tree damage - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 05-31-2011, 06:27 AM
alfabmw1 alfabmw1 is offline
Mein Auto: 2001 325 xi
I was a way for a couple of weeks, so my BMW sat mostly unused.
When I got back, my wife mentioned that she drove the car once, and that my brakes sounded terrible. I took it for a ride, and not only noisy, but severe vibration under braking. Strange since the car was fine before I left.
It turned out that the rear rotors had a build up of rust from sitting. I pulled the rear rotors (BTW pads and rotors both have plenty of surface on them), and sanded the rust off, and now all is well.
The other thing that happened was that tree buds and pollen built up on the car. My wife cleaned it off once, but not often enough to prevent the outline of the buds from being etched into the paint.
No amount of polishing or compounding helped. I guess it is either wet sanding or a re-paint(:
Not a fun thing to come home to.....
Old 05-31-2011, 07:20 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
ALL rotors will rust up from sitting during inclement weather (and we`ve had plenty of that this year). A few vigorous stops is all that`s required, no need to sand `em..
Find a good local detailer, and speak to him about possibly repairing that clear coat.
The road goes ever onward....
(R.I.P. Jever)
Old 05-31-2011, 10:29 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
You should see what the sea gull shyte does to cars where I live.
Old 05-31-2011, 11:40 AM
Kubs Kubs is offline
Mein Auto: 2003 330 Ci
Wet sanding is a good idea, and doesnt cost anything but time. Just make sure the car is clean, sand with 1500-2000 grit paper, polish with rubbing compound then swirl remover.
Old 05-31-2011, 11:46 AM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
I take it that contaminant removal using a clay bar has already been attempted, right?
2006 325Ci
Old 05-31-2011, 03:56 PM
yup, forgot to mention that... I also tried tar and sap removal solvent first, then went to clay, then polish, then compound.
Old 05-31-2011, 03:59 PM
Thanks Kubs and Fast Bob, I will speak to some buddies of mine that do body work. I am hoping that the wet sanding will be the answer.
I called the insurance company to ask if this type of damage is covered, they are checking into it for me.
Old 05-31-2011, 04:22 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
What level of polish did you use? Buffer? You won't solve the problem with some auto store polish and a rag, you need a machine, pads, and good quality polish.
There are many levels of polish and I've seen the nastiest of cars returned to better-than-new condition with a proper detailing and correction work. A pro can do that with ease.
Jeff R.
Old 05-31-2011, 06:51 PM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
You would be amazed what you can remove from paint with a clay bar.
Old 05-31-2011, 09:28 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I have always parked under maple or (horror) linden trees; wax is essential and regular washing helps but clay gets everything.
Brakes rust when you park. Don't park outside for long periods of time. A lot of rust will develop. I unfortunately have experience in this area.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 06-02-2011, 03:51 AM
No, did not go that route yet, I'll step things up this weekend.
Old 06-02-2011, 07:44 AM
Rust is inevitable in the pad contact areas of the rotors and will clear up after braking a couple of times. As for rust in the rest of the rotors, that can be avoided by changing to the newer zinc-coated or painted rotors. There are a number of brands and styles to choose from. My car is currently running with Zimmerman Coat-Z rotors, no rust for the past 9 months or so.
2006 325Ci
Old 06-02-2011, 09:48 AM
Past Sponsor
Mein Auto: e39 5
We carry the zimmerman Z coats and Balo is doing coated rotors now as well.
http://www.eaceuroparts.com/parts/BM.../5510/36152298
