E30 (1982 - 1993)
Old 05-27-2011, 04:48 PM
downhiller's Avatar
livin large
Originally Posted by joecassie View Post
yeah cause mine cant handle the s52
it could, ive seen someone throw over 300hp in a gretag
Old 05-28-2011, 12:09 AM
joecassie joecassie is offline
Mein Auto: e30 325es86
yeah but i need a new one anyways so tell me what i should get than like what engin and transmisson
Old 05-28-2011, 08:00 AM
E30 hobby car E30 hobby car is offline
Mein Auto: 1986 325e 4 door auto
what do you use the car for?
get something you can build on.
around here, M52's are around $1200-$1500 for a quality rebuilt used motor.
that is with out tranny and the good bits.
Old 05-28-2011, 11:29 AM
i plan to spend about 2000
Old 05-28-2011, 11:30 AM
you think that well be good or should i get more
Old 05-28-2011, 02:17 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
$2000 is more than enough for an S52, I believe they run for 1500 around here. As markseven said, get and S52 and a ZF trans and you're set. Only downfall is you need to buy all the swap parts and custom build your own exhaust.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 05-28-2011, 04:49 PM
i live in citrus heights california the place i went to tryed to sell me an 325i engin for 1000
Old 05-28-2011, 04:57 PM
i just called a place arpund here and they said they would sell me a m52 for 1500 puls a core chagre of 1000 and the zf 5 speed for 400 so i neeed about 3000 dose this sound all right
Old 05-28-2011, 05:06 PM
engin swap
dose 1500 sound good for an m50 + 1000 core charge and a zf 5 speed for 400 sound good i would get an s52 but they are selling it for 3300 so are these fair prices
Old 05-28-2011, 06:40 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
If he asks again "what should I get" I'm gonna temp ban him
I Timothy 2:1-2
Old 05-29-2011, 05:49 AM
dream chasin'
NO! M50 is NOT worth 1500. The ZF trans is pretty much in the ball park, little steep but...400 is fine if you want it ASAP.
It's been said many times, in the 1500-2000 price range you want an S52. Go on www.r3vlimited.com, don't post there like you do here, you will get flamed and run off the board. Just post in the "WTB (Want To Buy)" section that you're looking for an S52 in your area for about 1500. If you want a little help AFTER you find the motor, you can post the link here and we will try and help you so you don't get ripped off.
Don't EVER pay near 1500 for a m50, not even an m52. M52 is worth about 1000, even that's a hundred or more high. M50 is pretty much worthless to someone likes us who knows about them, around the 500 dollar range.
I think that might be good Mark, .
Old 05-29-2011, 07:11 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
How about an LSx swap?
mujjuman
Old 05-29-2011, 11:04 AM
ok i will and thanks and ill post the link to you so you can help me
Old 05-29-2011, 01:21 PM
dream chasin'
You shut up...I won't even get into explaining why.
Old 05-29-2011, 01:25 PM
downhiller's Avatar
livin large
go ls7 with a 6spd. then slap twin turbos on. very few cars will be able to keep up
Old 05-29-2011, 01:39 PM
tappa tappa toit
Mein Auto: hoopty
Because it's not a BMW engine hahahaha.
But those are cheap, ridiculously fast, and from what I hear are easy to swap.
mujjuman
Old 05-29-2011, 01:59 PM
an audience of One
http://www.e30tech.com/forum/showthread.php?t=106690
I've decided to put my euro s50 and 6-speed up for sale. I bought it from Alex Lipowich of ABL Original Parts back in fall of 09, with 64k miles on it. I have since put about 2-3k miles on it, and never once had an issue with the engine - it ran like a raped ape. No vacuum leaks, VANOS noise, rough running, nothing. The engine came out of a '99 MZ3 (which has the best laid out engine harness for swapping into an e30), and the trans out of a '97 M3 Evo. This trans will bolt to any 24v engine and uses the same exact clutch assembly as a ZF 5-speed.
Engine comes with:
-AKG 24v swap specific engine mounts in as new condition (these locate the motor perfectly in the bay)
-e34 525i oil pan with brand new BMW oil pump and pick-up (app 2-3k miles on this now)
-324TD fan clutch with 0 miles (slimmest fan clutch BMW made for easy mechanical fan fitment)
-C101 connector hard-wired in place of x20. Pins are set up for an '89 M3 which is about 90% similar to any other E30. Only a couple pins would have to be moved, and I could do that no problem for a buyer.
-fuel pump relay added to engine harness for increased plug & play ability into a E30 (stock mz3 fuel pump relay is on the body harness).
-EWS II modules included plus two transponder keys .I have all wires on EWS harness labeled for easy wiring.
-smog pump deleted with correct BMW block-off plate
-All other engine rated paraphernalia including Siemens MSS50 DME, 3.5" MAF, etc.
Transmission includes:
-AKG e21 tranny mounts with enforcers cups in as-new condition
-All newly replaced OEM BMW shifter assembly - every single wear item now has less than 3k miles
-good condition large guibo
-new z3 1.9l shift lever
-sachs throwout bearing with 3k miles since new
Price is $5500 OBO for the engine, $850 OBO for the 6-speed. package deal is $6000, plus shipping on a pallet to your location. Engine is also available for local pick-up in Pittsburgh, PA.
I Timothy 2:1-2
Old 05-29-2011, 11:21 PM
dream chasin'
No you buffoon. Because then he will ask a million of the same questions over and over again about that. I'm all for an LSx motor in an e30.
Old 05-30-2011, 08:30 AM
an audience of One
Tone it down, Zach.
I Timothy 2:1-2
Old 05-30-2011, 09:58 AM
tappa tappa toit
Mein Auto: hoopty
I still vote LSx swap
I want to do it in mine!
mujjuman
Old 05-30-2011, 01:33 PM
ok i think im getting a m50 so what transmisson do i need cause i cant get the s52 its going to cost me to much
Old 05-30-2011, 02:55 PM
dream chasin'
zf
Old 05-31-2011, 01:33 PM
nmonk2010 nmonk2010 is offline
UptownBoy
Mein Auto: e30
I just replaced mine OEM direct from BMW. It cost $13k CDN all-in and includes a 3 year parts and labour warranty. Yes, call me nuts, but it was the best decision I made. It was either by a brand new car, or keep mine which was in mint condition, just had major engine problems.
Old 05-31-2011, 01:49 PM
an audience of One
What car? What engine, cause your post info shows that you have an E30...
I Timothy 2:1-2
Old 05-31-2011, 07:58 PM
UptownBoy
Mein Auto: e30
1990 325i cab, e30, original stock inline 6 engine. It was pieced together from all over the world. I'll post a YouTube video later - it sounds amazing.
