6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
#351
Hi... Im from Spain and here is very difficult to find some parts for our 6. I bought Xpipe from Summit racing in USA for about 380$ shipped and i installing it for myself...Now it sounds a lil bit F1 with x pipe in the front....but only noticiable when push the gas up..
#352
Fellow 6ers,
After reading this thread IM ALL IN! Lol.. |
#353
What Model number Magna Flow?
I just installed the X-Pipe and bypassed the 3 resonators on my 2006 650i based on this thread.. Thank you all! Great info.
Sound improvement is great, but i want more! I want to buy 2 Magnaflow mufflers to add on (I hope this will add the "more" I'm looking for) I need to know the manufacture part numbers for the exact part that fits my car... Can anyone help? Single tip and duel tip would be nice. Also... How much volume / sound quality will i get out of adding mufflers. considering I have already done the above mod... Is it even worth it, or should i stay with my stock mufflers? Thanks in advance for the help! -oRIDDLERo Last edited by oRIDDLERo; 11-13-2012 at 01:01 PM. |
#354
The exhaust will be much louder than stock if you install Magnaflows. Personally I think the Magnaflows sound good but they are a bit much for a daily driver.
Here are two threads with part numbers and video clips. The Mangaflow site also has video clips. Note that the Magnaflow site only lists an entire system for the 650i, which you don't need because you've done the resonator delete. The Magnaflow exhaust thread... Magnaflow Exhaust just put in This clip is with one of the two resonators removed.
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
#355
For my 2006 650i I'm pretty sure it is either: Magnaflow part #11366 (Center/Offset) or Magnaflow part #11235 (Offset/Offset) Then i just need the part number for the tips. (Does tip length matter) I'm usually pretty good with forum/net research, but this is driving me crazy. I just want the part numbers so i can place the order and get this over with! I even called Magnaflow and the guy was unsure (wanted measurements). Thanks again! |
#356
Very nice. Where did you put the x-pipe - and I presume you kept stock rear mufflers?
Jon Quote:
#357
You can see it in the picture I posted - it is right up front where the bullet resonators used to be. My x-pipe was fabricated on site, and it sees both bends come together a bit less than others I have seen, but my understanding is that it will still do the job of equalising pressure between cylinder banks. Either way, it works and sounds good.
#358
Just got my resonators deleted! It sound good but I need a little more rumble. Should i go with Flowmaster mufflers or Magnaflow?
Sent from my PC36100 using Bimmer App
Here is link for the part you need cheap: http://www.ebay.com/itm/310481239844...84.m1439.l2649 And the stock tips for them: http://www.ebay.com/itm/120851613894...84.m1439.l2649 Last edited by oRIDDLERo; 11-28-2012 at 10:57 AM. |
#360
Has anyone tried to install 2 cutouts just in front of the mufflers? any pros or cons on that mod? would there be even enough room to install a electronic valve.
#361
On a side note, has anyone tried an exhaust combination with M6 mufflers on the 6ers? I have a 645ci, got my hands on some oem M6 mufflers fairly cheap - mainly because I want to install a M6 rear bumper. Sound should be different IMO - the pipes are bigger, and i'm sure the baffles inside the M mufflers are tuned differently as well. |
#362
don't do it...I tried that with a V6 audi before, two cut-outs right after the headers....thing was louder than a drag car, sounded absolutely fugly, and the drone inside the car will make you get addicted to advil after about 30 min of driving. I really don't see a V8 bimmer be any better
#363
I took the plunge and removed my two round resonators over the weekend with straight pipes. The difference in sound is very very subtle compared to stock. I'm hoping to eventually replace the mufflers to achieve the desire sound. For now, I'll have to settle.
#364
M6 mufflers sound good imo on 650s havent heard it on a 45 but it should bevthe same
650i sport hud asanti af132 |
#365
Ok so all this talk of deleting and removing and changing, but how will this effect emissions testing? Our smog test here in Cali are very strict?
Will they still pass the test after the mods if so I'm gonna do mine too. Eurowned- did you take an after pics. thanks!
If you don't touch the cat/ catalytic converter, you will pass smog for sure. Even some catless system can pass the smog (might fail the visual test).
My phone is really bad so the sound record not really show the real sound. If you guys come down to the SoCal meet, I will prove to you guys that 650i can sound so good. The M6 Eisenmann Race is a total different beats compare to Remus or Magnaflow. Magnaflow will give you a brum brum typical new generation muscle car sound. Eisenmann race is another stoy. I'm loving my 6 sound.
![]() 2009 BMW 650i Cabrio (daily drive) 2011 Audi A4 (groceries, bully, road trip, winter beater, family car) BMW CCA ID: 473647 Last edited by reytran; 02-25-2013 at 11:03 PM. |
#367
Did you also delete the center "box"/resonator and replace it with an X-pipe? Most folks on this thread (including me) took out all three and installed an X-pipe in place of center box. The sound is still subtle but a little louder than just taking out the two resonators, especially at WOT.
Regards, Greg '07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs '11 Acura MDX Advance with Entertainment pkg for the family - no mod's
#368
On the side note, I really miss the exhaust note from my RS4 with Magnaflow exhaust. |
#369
Ok - very little change with deleting just the two front cans. Might get the sound you're looking for if you do mufflers, but the x-pipe is easy, cheap and always reversible - might be worth trying first to see if its enough for you. Good luck.
#370
modified my exhaust system today
Today I finally did some work to my exhaust system. I installed two 2 1/2 inch cut outs right in front of the mufflers. Now I can have some "sound" when I'm driving and my wife can switch to the original sound when she is driving. Sounds awesome when idling and still not too loud when hitting the gas.
20" wheels 245/35 - 285/30, black grill, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks, AC Schnitzer pedals, Sprint Booster, electronic exhaust cut-outs, red brake calipers (painted) |
#371
Can you post a video/sound clip? I've seen others comment on how loud this type of mod is. Would love to hear what it sounds like. |
#372
once the weather is better I will make another video with a better camera and some drive-bys
#373
What is a sounder? Do all BMWs have it?
#374
Stock exhaust good. Other exhausts bad.
#375
![]() 2009 BMW 650i Cabrio (daily drive) 2011 Audi A4 (groceries, bully, road trip, winter beater, family car) BMW CCA ID: 473647 |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
