Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 05-24-2011, 08:07 PM
DLS_91_525i's Avatar
DLS_91_525i DLS_91_525i is offline
I Wonder What This Does?!
Send a message via MSN to DLS_91_525i
Mein Auto: 91 BMW 525i 72 VW Variant
Question 1991 525i ProCharger or Turbo?
So I got my hands on a M50B25 out of a 1992 525i with just a little over 160,000 on it.
I'm going to get it bored to clean up the cylinders, new piston rings, rod bearings, crank bearings, etc. All new gaskets, new timing chains. Plus all the little nick-nacks to get everything back up to specs.
Getting head studs and thicker gaskets as well.
The BIG question is. Should I go with a ProCharger or a Turbo on the motor?
So what do you guys think and why?
Feel free to ask any questions if you need any more Info about the build.
DARRiN
Old 06-12-2011, 05:03 AM
ICS ICS is offline
Account Under Review
Mein Auto: Turbo BMW's
DARRiN
Please keep in mind the early 92 M50B25 does NOT have knock sensors. Get yourself a 3281 -5281 engine 1996-1999 Years, convert it over to OBD 1 93-85 Harness (325 or M3) ECU completed set up.
I would def do a turbo kit hands down.
Hope this helps, best of luck.
Old 06-12-2011, 04:37 PM
Why is it a problem that it does not have a Knock sensor?
and why would you choose a turbo?
DARRiN http://www.facebook.com/E34DARRiN3391
(1991 BMW 525i 260,XXX miles)
(1972 Volkswagen "The DEATHWAGEN" Variant 64,XXX miles)
Old 06-17-2011, 07:26 AM
GG///M3 GG///M3 is offline
Mein Auto: Earth
Turbo you will have more choices down the line. I would suggest getting in contact with Trm as they have tuned ur setup with no knock sensors in the past I believe. What kind of power are you looking to make. Going with a super charger is cheaper, but I wouldn't go that route being that it is a e34 and it will feel under powered for the weight of the car.
Old 10-02-2011, 05:45 PM
snailinduced's Avatar
snailinduced snailinduced is offline
BoostJunky
Mein Auto: 328is
The semantics of knock, pre-ignition, or detonation can be argued among automotive engineers, however it is basically an uncontrolled ignition of the air fuel mixture. The uncontrolled part means that it doesn't occur at the desired time in the combustion cycle. Normally the timing of the ignition is designed to maximize pressure in the cylinder so that it will push the piston down with the most force. Knock can cause high cylinder pressures at times when it actually counteracts the force and also cause shockwaves within the cylinder. It is the shockwave that emits the characteristic "tinkling" sound you often hear when the engine is knocking. In reality by the time you hear knock the chances are that the engine has been knocking for a while. Car manufacturers are continuously researching better ways of detecting knock and in the future we may see more direct methods such as pressure sensors and ionized current measuring however the majority of cars still use an indirect method of detecting knock by listening to the ringing sound of the cylinder using a piezoelectric knock sensor.
Turbo or supercharger? Well, they are two different beasts. Turbochargers generally allow for much higher bhp numbers as boost can be cranked up depending on your engine setup. Chargers are more reliable but generally have lower hp numbers. What are you looking for?
Photobucket
T40E HKS TIAL GODSPEED 666 Ireland Engineering
UUC SSK SDS MGMT AA DDM 803HFM 42#
Old 10-02-2011, 08:49 PM
I'm wanting horsepower gain, but I would also like the uniqueness of a supercharger on a E34 and I love that signature whine of a supercharger! oh! and Reliability is key!
Old 10-02-2011, 08:54 PM
BoostJunky
Mein Auto: 328is
Then go supercharger.
Photobucket
Old 10-02-2011, 08:58 PM
I so want to, but I've never seen a E34 with a supercharger.
Do they even make them???
Old 10-26-2011, 07:47 PM
Gravik Gravik is offline
Mein Auto: '91 535i/5
Someone on bimmerforums has a supercharged E34 535i and if I'm not mistaken a couple guys SC'ed their 540i. Haven't seen a S/C'ed or turbo'ed 525i yet though :/
Supercharger whine sounds great But so does the sound of the turbo spool and BOV.
1995 525iT. 178k miles. Magnaflow exhaust. SOLD
1991 535i/5. 154k miles. |DT Performance Catback|CAI|Miller MAF/WAR Chip|NEX coilovers|Beyern Rapp Staggered wheels| SOLD
FOR SALE
Old 10-27-2011, 09:39 AM
Agreed! It's such a hard choice!
DARRiN
Sent from Samsung Gem using Bimmer App
Old 05-21-2012, 06:51 PM
ghart ghart is offline
Mein Auto: 91 525i
It would be a novelty if you could supercharg it as well as turbo charged it. I know Lancia tried that.
Old 07-02-2012, 06:51 AM
WDRAcing WDRAcing is offline
Mein Auto: 99 540iA
Just a couple things to add. Preignition is what takes place before the spark event, detonation takes place after the spark event. Preignition almost always ends with a part of the rotating assembly failing, usually a hole in the top of the piston. Preignition is mostly caused by the wrong heat range spark plug and or hot spots that form in the combustion chamber. Using the correct heat range plug and making sure the engine doesn't run hot will keep preignition at bay.
Detonation is what happens when you reach the octane limits of your fuel. The higher the octane of the fuel, the more boost you can run for any given compression.
The "knock" sound you hear is actually the rotating assembly absorbing the shock load of the detonation occurring. A motor can run for years with light knock. However, you don't want ANY knock if you're going the FI route.
The best way to avoid detonation is with alcohol/water injection.
Turbo's own superchargers in almost every category. You'll make more useable power with a turbocharger since they'll produce full boost far earlier in the rpm band then a centrifugal supercharger will. The centrifugal type supercharger, imho, represents the ultimate form of lag. Full boost comes as you max out your desired rpm.
Lets use 8 psi as a max boost #. The turbo will be at full song by 3000 rpm give or take, the supercharger will likely only be at 3-4 psi and slowly increasing until it peaks at 8 psi as you're about to shift.
Another benefit of the turbo is your ability to control the amount of boost with a simple controller. No swapping pulleys around and messing with belt tension. Just turn a knob. Very handy because you can run 2 different levels of boost real easily. Use a low boost setting for daily driving and use a high boost setting while you're at the track, or feel the need for a little irresponsible hwy driving.
WD
