E30 (1982 - 1993)
Old 05-29-2011, 09:57 AM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
87 325is drive shaft removal
First thread in the e30 section woo.
anyways,
Trying to replace my carrier bearing and aparently my guibo too and i for the life of me can not get the driveshaft out. I have un bolted the 4 nuts on the rear of the shaft (to the diff) and the 6 nuts on the guibo removing the 3 bolts i can get out. carrier bearing is un bolted too, now from the looks of it the shaft should collapse or slide in on its self and give you room to drop it out but no such luck.
probably a simple answer but its appretiated nun the less, really want to have the dirty thirty ready for the upcoming auto x and the rally-x after that.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 05-29-2011, 10:01 AM
jayster0966's Avatar
jayster0966 jayster0966 is offline
Bimmer Loyalist
Mein Auto: E24 E39 E83
Is there not a threaded nut at the center of the shaft that you can turn with a large wrench? So that shaft may slide inward. Also lower trans suppro bracket a little to give yourself a little more room to move the shaft a bit.
Old 05-29-2011, 10:06 AM
Fast Cars Suck!
didnt notice the nut but wasnt looking either will go pop back under the car, thanks for the quick response.
Old 05-29-2011, 10:42 AM
Fast Cars Suck!
ok i see the nut, went a bought a pipe wrench so i had something to fit it, but now that too massive to fit on it and have any room w/o hitting the exhaust...which i cant pull because the PO decided to fit a long tube header and striped one of the bolts holding the 2 pipes onto the header
Old 05-29-2011, 10:43 AM
Fast Cars Suck!
anyone happen to know what size hand wrench would fit that nut? (googling now)
Old 05-29-2011, 04:25 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Guesstimate and buy a bunch, then return the ones you didn't need
Old 05-29-2011, 08:42 PM
downhiller's Avatar
livin large
i used a giant crescent wrench. but then realized i could turn it by hand
Old 05-30-2011, 05:15 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Avoid dis-assembling the prop shaft into two pieces! If you have to do this...first mark the two sections so that you can re-assemble it in exactly the same position...failure to do this can lead to vibration at certain speeds!
Old 06-02-2011, 12:11 PM
Fast Cars Suck!
i disasembled it (needed to replace the CSB) but marked it first went back to gether fine, cant belive i missed the giant nut ha ha oh well, now she is still vibraating under hard loads at low speeds, if you baby the throllte no issues, i have tried re preloading the bearing so many times i want to shoot myself, so it leads me to belive the the guibo, which is showing some age is the culprate (sp?) guss ill order that tonight and repeat the process, unless you guys have another idea?
Old 06-02-2011, 01:54 PM
Bimmer Loyalist
Make sure all the u-joints are not binding or have excessive play. Don't forget to re-tighten that center nut as well.
Sent from my iPhone using BimmerApp!
Old 06-02-2011, 04:54 PM
Fast Cars Suck!
center nut is nice and tight, and ill check the u joints, correct me if im wrong but if they are binding then it is time for a new driveshaft correct?
Old 06-02-2011, 05:37 PM
downhiller's Avatar
livin large
you can replace them. people have done it. but its a PITA
Old 06-02-2011, 05:50 PM
Fast Cars Suck!
well hears to hoping its just the guibo
