Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3!
Old 05-30-2011, 05:35 PM
nymetsfan nymetsfan is offline
Mein Auto: 2011 M3 sedan
2011 M3 Sedan Rattles
Hello,
I have a 2011 M3 sedan with roughly 1800 miles on it. I hear rattes from both front doors/windows on doors quite often. Of course, when I had it in for the 1500 mile service there was no rattle.
Has anyone had this issue and what was the cause/fix?
Stephen
Old 05-30-2011, 05:40 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
This is a common problem.
Hit the search button and find recent posts.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
13 Porsche Cayenne Diesel
BMWCCA 4215
Old 12-19-2012, 09:45 AM
thekurgan's Avatar
thekurgan thekurgan is online now
Bad Lieutenant
Mein Auto: S65B40 Powered
I'm reviving this as I've recently solved the window, armrest and the dash rattle/squeak in the E90M3.
1. windows - the dealership will use 1Z's gummi pflege, which works for a while, but I use Krytox from DuPont, doesn't take much to massage into the seals that are on the door itself and lasts through ultimate cold and heat.
2. Armrest rattle was the button that locks the rest, it needed some krytox on the areas where it rests inside the mechanism near the spring
3. Dash rattle between the mid vents and the HVAC controls. Pry the middle vent section out from the right side and the left side near the "start/stop" button gently with plastic door remover pry bars. No need to disconnect the wires. You'll see the ridge on the HVAC section where the center piece rests, it needs a little krytox on a q-tip and go all the way across. While you've got this panel removed, place felt behind the HVAC unit so when it slides back into the dash, it isn't plastic on plastic.
Hope this helps, sorry no photos yet.
08 E90M3 6MT Alpinweiss/Schwartz
