Teves MK 20 DSC III (from 4/99 MZ3's)
14K views 15 replies 9 participants last post by  Pinecone
#1 · (Edited)
Does anyone know "for sure" what a momentary press of the DSC switch does to the system versus a >10 second press?
#2 ·
I drove a friend's e46 M3 and I tried the two different modes of the DSC on that car.
DSC button press:
- Deactivates traction control but stability control remains active (corner brake control to correct for slides)
- DSC light illuminated on dash
DSC button press + hold for 10 seconds:
Deactivates traction control and stability control
- DSC and "Brake" light illuminated on dash
#3 ·
DSC button press:
Except for the "brake" light illumination, that has been my observation as well.
#6 ·
That the only difference between push and push+hold is that with the latter the warning light will stay on until the car is switched off. But dynamically....nada, no difference.
A friend who runs an e46M3 ('02) has the same experience.
This is especially noticed tracking: Lime Rock is a good example, The Downhill turn will tend to work the individual braking hard if DSC is on. if you punch it off you would expect the same unmistakable feeling to happen on that corner...but it's just not there.
On non M cars there IS a difference.
Like I said I wish there was a multistage DSC...
#7 ·
Retrofit to 98 M
Anyone have an idea on how (im)possible it would be to retrofit ASC or DSC to a 98 M which came with no traction control at all?
I read about http://www.racelogic.co.uk/traction.htm which seems like a great system, but I heard that because it cuts spark that it trips the Check Engine Light so it's not a good choice for our cars...
#8 ·
I would say its not worth the $$$ to retrofit.
FWIW, you can also configure racelogic's system to cut fuel. Although with either method (fuel or spark) I would be worried how a non-OEM system might affect the catalyst.
Jonathan
#11 ·
Two obsercations:
1) On the earlier E46 M3s after lots of trying various things, the DSC is either on or off. There is no 10 second button push. It only gaults the system and wil not allow the DSC to be turned on by the button, you have to cycle the ignition.
2) Later E46 M3 DSC seems to be programmed ddifferently, and tends to be more intrusive. Not sure if they have two levels like th enon-M cars do.
Not sure when the changeover was, but 2002s only seem to have one level and it is pretty unobtrusive. 2004s seem to be more intrusive.
#12 ·
RS2 said:
This is what I have been able to find about the DSC button in various BMW documents.
The E46 M3 has the Teves MK20 system but some info implies (not confirmed) it has been updated to MK60 as from 09/2001 production (2002 year model).
/RS2
Teves MK20:
The DSC system is active when the ignition switch is turned on, the DSC system is de-activated when the button is pressed. The DSC warning light will be illuminated when the system is off. The activate the system, press the DSC button again to restore operation.
Teves MK60:
The DSC button is located on the SZM, however the SZM provides no processing, it is
simply a housing for the button which is hardwired to the MK60 control unit. The DSC Button features two functions that can be set by varying the time the button is held down for.
Short press <2.5s: DSC light illuminated. Only the yaw control of the DSC is deactivated. The ADB and DBC functions remain active. A higher slip ratio is allowed up to 42 mph for the purpose of improving traction in slippery conditions. ASC uses different thresholds.
Long press >2.5s: DSC light and general brake warning light (yellow ABL) illuminated. All ASC, ADB, DSC, GMR (yaw control) and DBC control functions are deactivated. Used for service and use on dynamometers.
Pressing the DSC button again returns the system to normal status. It is not possible to go directly from one function to the next without first returning to normal status.
2002 Model Year Update:
The DSC system MK60 has been further developed with regard to certain functions. The ADB function is further improved in DSC by Dynamic Traction Control (DTC). The differential effect is brought about here by active brake intervention and DSC monitoring. The yaw moment is taken into consideration which eliminates the danger of the car swerving as it corners. The DTC is activated by pressing the DSC button. The active DTC system is indicated by the DSC warning light in the instrument cluster.
Just trying to verify the following:
Disabling the DSC on my '01 M coupe (Teves MK20) results from a short press. I'm assuming that holding the switch >10 seconds initially disables it too and then the additional hold of >10 seconds puts it in fault mode requiring an ignition off on cycle to reset. When it goes to fault mode, I'm assuming that it is still disabled like the short press.
John is going to try checking this out at his local dealer.
In other words, there is no need to hold the switch for >10 seconds to disable it in my car.
#13 ·
As I mentioned above, I can safely say I have enough sideways at the limit experience to tell you one push is all you need and all you get :D
