E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Does It Exist?
Hello gents (and ladies), I've come across someone selling a 1982 325e that he says is a two-door. There were no pictures and limited information on the site I saw it. I've researched a bit, but can't find any solid evidence that BMW actually made it. The four-door info comes up, but nothing about two-door... can someone clarify if it exists? TIA
Sent from my ADR6300 using Bimmer App
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506 BMWCCA Member# 451235 (Summer) 2001 330Ci - ZSP (Winter) 1994 530i "Greenie" - LOADED
clarify that what exists ? a 2 door 325e ? there were hundreds of thousands of them.
learn to use google.
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
I think he means '82 325e
WTB: Minty Seat Belt Receptacles - Front |
My question is: is there such a thing as a 2-door 1982 325e. All previous search efforts have turned over this same spec list: General Information Make BMW Model 325e Production Year 1982 Country Designer Production Number Model Code Model Family E30 Chassis and Dimensions Chassis Type 4/5S SAL Number of Doors 4 Wheelbase 2570 mm (101,2 in) Front Track 1407 mm (55,4 in) Rear Track 1415 mm (55,7 in) Length 4325 mm (170,3 in) Width 1645 mm (64,8 in) Height 1380 mm (54,3 in) Ground Clearance Length / Wheelbase Ratio 1,68 Weight 1140 kg (2511 lb) Weight Distribution (front/rear) %51 / %49 Fuel Capacity 55 litre (12,1 Imp gal , 14,5 US gal) Aerodynamics Drag Coefficient 0,37 Frontal Area 1,86 Cx 0,69 Engine Specifications Engine Manufacturer BMW Engine Location Front Engine Alignment Longitudinal Engine Construction Coolant Type Water Engine Type SOHC Number of Cylinders and Placement S-6 Valves per Cylinder 2 (Total of 12 Pieces) Engine Displacement 2693 cc (164,34 cu in) Bore 84 mm (3,31 in) Stroke 81 mm (3,19 in) Bore / Stroke Ratio 1,04 Unitary Capacity 448,83 cc/cylinder (27,39 cu in/cylinder) Number of Main Bearings 7 Compression Ratio 9 : 1 Fuel System Type Bo Mo fuel injection Aspiration Type Normal Compressor Type - Intercooler Type None Catalytic Converter Yes Maximum Engine Power 120 HP (89,5 kW) Maximum Engine Power rpm 4250 d/d Maximum Engine Torque 230 N.m (169,7 lb.ft , 23,5 kg.m) Maximum Engine Torque rpm 3250 d/d Engine Torque at Max. Engine Power rpm 201,1 N.m (4250 d/d) Power / Weight Ratio 105,3 HP/ton (78,5 W/kg) Power / Engine Displacement Ratio 44,6 HP/litre (33,2 kW/litre) CO2 Emissions Fuel Consumption 5.9/7.8/11.4 l/100km 90 km/h / 120 km/h / urban Performance 0 - 80 km/h 6,6 s 0 - 60 mph 0 - 100 km/h 10,1 s 0 - 160 km/h 28,3 s 80 - 120 km/h (in top gear) 0 - 400 m Acceleration 0 - 1000 m Acceleration Top Speed 194 km/h (120,6 mph) Gearbox and Transmission Transmission Type 5M Top Gear Ratio 0,81 : 1 Final Drive Ratio 2,93 : 1 Drive Wheels RWD (Rear Wheel Drive) Handling, Suspension Geometry and Brakes Steering Type rack & pinion Steering Turns (lock to lock) 4,25 Turning Circle Diameter Suspension (front) Suspension (rear) Brakes (front/rear) Brake Disc Diameter (front) Brake Disc Diameter (rear) Wheels (front) Wheels (rear) Tyres (front) Tyres (rear) Blah Blah Blah Blah Blah Whether it is here: http://eng.motorsporlari.net/car/tec...21837&make=BMW Or here: http://www.carinf.com/en/86d046267.html Or here: http://www.getcarspecs.com/bmw/1982-bmw-325e Or here: http://www.scorpiocars.net/cars/car.php?ID=1718 No where have I seen mention of a 1982 325e with 2 doors. Search results are a little squirrelly, since it was the first year of the e30. I will know more when I see the car, but that won't be for another week, when the guy has some time to show me. He has no pictures to send of the car in the meantime. I wanted to do a little homework before-hand so I know what I'm looking at, but I'm flying blind at the moment... TIA (again).
Global E30 production totals by model
Model Year Units produced 318i 1987–1991 89,637 318is 1989–1991 41,234 320is (2 door) 1988–1990 2,542 320is (4 door) 1987–1990 1,206 325i (2 door) 1985–1991 113,906 325i (4 door) 1985–1991 83,080 325ic 1985–1993 85,246 325ix 1985–1991 29,589 325e (2 door) 1983–1988 114,498 325e (4 door) 1983–1988 74,789 M3 1986–1991 17,184 wiki-pedia-.-com
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
![]() 1991 318is (Daily Driver) 1983 E21 320i (Chumper) 1968 Chevy Nova/Chevy ll (383 stroker)
He was responsible for the Z1.
So according to ole reliable Wikipedia, no E30s were made in 1982!
![]() Sent from my ADR6300 using Bimmer App
no, but they were sold in 1982. just like how 2012 models are out now.
Yes, MY 82 is correct. Thanks markseven.
They made E30s in 1982, and deemed them 1983, just as they now make 2012 models in 2011... but did they make them in 1981, and deem them a 1982 model? Wikipedia notes the e30 was from 1983 to 1993, while our very own site notes the start of the model in 1982. Anyhow, it seems a moot and insignificant point now. I will just have to wait until I see the car this weekend. Carry on. Sent from my ADR6300 using Bimmer App
its trying to prove whos right and whos wrong and whos right on the intrawebz. remember only one of them leaves you with alil dignity.
and....a moot? wtf? must be my misunderstanding of you east coasters
- adjective 1.*open to discussion or debate 2.*of little practical value dictionary-.-com Sent from my ADR6300 using Bimmer App
he was using moot and insignifiicant to describe the point .. which is redundant.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
