Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-31-2011, 02:17 PM
jason54r jason54r is offline
Mein Auto: 1984 533i
1984 533i brake lights not working
I just bought a 1984 533i. I am new to BMW's. The brake lights will not light up. I checked continuity in the fuse,light bulbs, and even the bulb holder. Am i overlooking something simple that I just don't know about. Please help.
email jason54r@yahoo.com
Old 05-31-2011, 06:40 PM
catso's Avatar
catso catso is offline
catso
I've had electrical contact problems from corrosion where the bulb holders go into the tailight assembly. Also corrosion in the bulb holders themselves. You can try cleaning up the contact areas or even replacing the holders, they're not expensive.
![/I][/FONT]
Old 06-01-2011, 02:05 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
If nothing else works, check your brake light switch on top of the pedals box. Also, make sure your light bulbs have a silver base not a brass colored base as these are known to create problems in our cars.
Jimmy Moreno
1995 530i
1986 535i
Old 06-01-2011, 03:32 PM
pedals box
Where exactly is the pedals box? I thought about some switch connected to the brake pedal, but could not find it.
Old 06-01-2011, 06:05 PM
Brake light switch
I found the brake light switch in the pedals box. I put my meter on it and had no continuity with the switch in both positions. It is bad right?
Would it be a bad idea to use a wire to make the connections and bypass the switch to confirm?
Old 07-06-2011, 07:58 AM
Mein Auto: 2006 X3
You could connect the wires to test it but if you have no continuity in both positions you just confirmed its bad. Replace it and pat yourself in the back!
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
