Old 06-02-2011, 08:35 AM
alfonso12 alfonso12 is offline
El Macho
Mein Auto: 1999 540i 6 speed sport
Remote Key battery
What battery to use for my non-diamond 99 540i remote key? 3V lithium CR2032 or 2016?
Any brand that I should stick to?
E39 99 540i 6 speed Oxford Green
Old 06-02-2011, 09:54 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
CR2016, says so on the back of the battery when you open it up. ANY brand will do.
Old 06-02-2011, 02:36 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto...see 2nd paragraph in pic below:
Q {BMW CCA Member #191509}
(SOLD)
Old 06-03-2011, 01:01 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I see the OP received a good answer.
In addition, if the OP would like DIYs and further ideas and references, the following, from the bestlinks, should be good reading:
- The truth about the BMW diamond key transponder (1) and proper initializing (1) (2) and the truth about the 10-key limit to programming your own keys at home (1) & opening, charging, recoding, & battery replacement (1) of the new-style diamond key (1) (2) (3) (4) (5) (6) & converting the old-style 1996-2000 "square" key to a diamond key (1) & how to replace the rubber key pads in the old style keys (1) (2) & what to do if your key is locked inside your car (1) & a description of the various types of BMW "Remote", "Illuminated", "Spare/Wallet", & "Valet/Service" keys (1) (2).
Old 10-11-2011, 07:27 AM
bluebee's Avatar
After reading the following, I added this to the bestlinks just now:
- How to replace the square key battery (1) (2) (3)
Old 02-26-2013, 01:22 AM
bluebee's Avatar
This should be generally useful for the square key battery description.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
