install flex disc 26111225624 - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 06-03-2011, 10:31 PM
joeditcanada joeditcanada is offline
Mein Auto: 1987 325i cabriolet
Is there an easy way to install flex disc. The manual says to take the drive shaft out first. Can the job be done by just unbolting and rebolting the disc?
Old 06-03-2011, 10:38 PM
jayster0966's Avatar
jayster0966 jayster0966 is offline
Bimmer Loyalist
Mein Auto: E24 E39 E83
You can try lowering trans support bracket about 1/2 way down. Then loosen the bolts that hold the flex disc. Next loosen the large nut in the center section of the driveshaft, this allows you to pry the forward section of the shaft back about a inch. Maybe neccessary to loosen center carrier bearing as well. After those procedures, I believe there will be enough room to replace the guibo without removing entire shaft.
Old 06-24-2014, 08:09 PM
mdarosa54's Avatar
mdarosa54 mdarosa54 is offline
Mein Auto: 1987 325e
I need to replace the center support bearing , can I just replace that but the too bolts ?
Old 06-24-2014, 08:11 PM
mdarosa54's Avatar
By taking off the 2 bolts and sliding the drive shaft off of it and then do the flex disk ?
