E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
ac pressure specs e30
does anyone have the low and high pressure specs for a 1991 325i e30 4 door factory ac system.
I had the system evacuated put in a new compressor and switched to r134a. On a very hot day the ac is luke warm. in the mornings before it gets hot the ac will be cool. I have manifold gauges and i want to do some diagnosis but need to know what the low and high pressure should be. thanks |
not sure of the pressure at the moment, but the evap temp (on your suction gauge) needs to be around 40' (somewhere around 40-45 psig i believe). you should have sweat on your suction line up to the compressor, but NOT on the compressor itself. if i get a chance, i will get my gauges and get you an acurate #...
the best way, since these are the r12 originally, then 134a numbers will be off. the best way to do a good check, wait till its low 90s out and add some 134a until it blows cold. what youll want is a thermometer to put in the vents and youll want somewhere around 40* comin out.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
with 134a gauges, 40' evap temp is 40'. there is no "off" to it. pressure/temp charts are a constant. 40' on r12 is 40', the pressure is different, thats the only difference.
i was mainly talkin the air comin out of the vents.
anyway...we both agree on the temp. to achieve a 45' supply air, the suction pressure would have to be @ 30 psig, which is 34'. head pressure should be in the 150-180 range.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
