Remote Control Key Fails Intermittently - Bimmerfest - BMW Forums
Old 06-04-2011, 01:47 PM
cincy61 cincy61 is offline
Mein Auto: 535xi
My remote control key on my 2011 535xi often fails when the car has been sitting in the sun. I have to manually unlock the car and hold the key to the steering column to start it. The temperature of the remote control doesn't seem to matter. The battery on the remote was putting out 3 V. I changed the battery to a new one (reading 3.1V) but it is the same. When the car cools off, the same remote works fine.
I took it to the dealer but it was working fine when I got there and they had no ideas.
Can anyone explain this to me?
thanks
Old 08-20-2011, 10:55 AM
Mein Auto: 535xi
Remote Key Fails Intermittently
Just a follow up - it began to fail more frequently (although still when the car temperature was elevated). I took it back to the dealer and they replaced the receiver and it works fine. The part took 7-10 days to arrive however.
Old 08-20-2011, 10:57 AM
planet's Avatar
planet planet is offline
Explore the space!
Mein Auto: On order: F10 535i
Thank you very much for following up with the resolution.
991.2 '17 Porsche 911 C4S (on order)
F10 '11 535i Titanium Silver on Oyster/Black (garage)
E46 '02 330i Steel Blue on Black (Gone but not forgotten!)
Old 08-20-2011, 11:24 AM
pera pera is offline
Mein Auto: 2011 BMW 528i
Did the dealer indicate what the issue was with the key fob ?
Old 08-20-2011, 12:39 PM
dadesidon dadesidon is offline
Mein Auto: F10 535
I am having this exact problem in Dallas and am 100% sure it is because of the sun. It only started after the car was left outside. It's annoying. I have a call in to the dealer to get this remedied. Will update.
Old 08-20-2011, 02:41 PM
Mein Auto: 535xi
It isn't the key fob. The receiver is an electronic device in the dash somewhere. Presumably as it heats up, some soldered joint or other stops working.
Old 08-20-2011, 09:08 PM
EIAlfonso EIAlfonso is offline
Mein Auto: 11 535ix MSport w/ Dot
Same thing here
I also noticed that it happens when the car is left outside
Old 08-21-2011, 09:37 AM
Thanks for the information cincy61
Old 04-03-2012, 10:35 AM
Diplomatic Diplomatic is offline
Mein Auto: 2012 535i
Glad I found this thread, now I know I'm not the only one, had my car for just over 2weeks and I'm expreriencing the exact same thing. If the car is parked outside for a few hours the remote stops working and I have to use the key to unlock the car and put the remote to the steernig column to start the engine. Leave it in the garage overnight and it works just fine. The guys in the delearship were looking at me with skpeticism all over their faces (ofcourse it didn't help that it was 8am and everything worked fine).....I'm going back tomorrow
Old 04-03-2012, 11:09 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
Looks like this issue is comming up recently.. added it to our sticky.. OP if you have the details of the serivice (What is the part number?) done please share it!.
Old 07-13-2013, 01:43 PM
maroon1991 maroon1991 is offline
Mein Auto: 550
I have the exact same problem with my 2011 550. Starts fine in cooler weather. If the car is left in the hot sun for >few hrs, the fob won't work. I have to hold it next to the steering column before it says "key detected, starting car possible". The car has been in the shop now 2weeks. Finally the SA called yesterday, says they will order a new antenna, will take another 4 days to get here. Is the antenna the same thing as the FBD or receiver, Ive seen mentioned above? The next thread #18 seems to be the same problem and the invoice included in one of the posts shows the part no.
Old 05-22-2015, 03:17 AM
ivo1bg ivo1bg is online now
Mein Auto: 2010 550I xDrive
Hi, I see that this is a very old thread, but recently have exact the same issue. What I have to do in order to fix it? What part I have to replace or maybe some resoldering I have to do?
Thanks for all suggestions.
Old 05-22-2015, 05:45 AM
north of 60's Avatar
north of 60 north of 60 is offline
Mein Auto: 535 xdrive
thanks
It's never hot enough here for me to experience FOB failure due to heat , mid 60's low 70's is miserable - hurry up August !
Mine fails when I park near high voltage power line , the radio looses all the setting also -
Other places the remote has a hard time -
On or near the Army & Air Force Bases radar system -
On the Clear Air Force Over the Horizon Radar Station -
Parked close to the control panels for a Locomotive size generator set while it's running of course -
Now for a few photos !
Old 09-05-2015, 12:39 PM
Bery Bery is offline
Mein Auto: 520D 2010
remotes not starting engine unless placed under steering wheel
Hello- my first message on this forum
I have the exact same problem.
For my 2010 520D ( 27k miles) both remotes open the doors of the car OK but when I press the start button the car will not start and the message on the dash is that I should hold the remote by the steering wheel- this starts the engine. The batteries on both remotes are OK.
An independent BMW garage could not help- the diagnostic report showed all sorts of issues but none related to this particular issue, so could not help
The problem started when on holiday in France where the temperature was about 30, warmer than London (where we did hit 36 this summer for one day and we had no occurrence). A BMW dealer in France had not seen this issue before and were perplexed
If this is a heat- related issue then surely BMW should cover the cost of replacing parts- all very frustrating and waiting 2 weeks for a dealership to look at the problem
Old 09-08-2015, 10:24 PM
Mein Auto: 550
See my initial post above from 2013. Ask your dealer to change the "antenna amplifier (FBD)". I have no clue what that means, but apparently it also controls the GPS. After my post in 2013, and 4 visits to the dealer, they finally diagnosed the problem, replaced the part above, and it has not happened again in the ensuing 2 years. Prior to that, the car would not start whenever the temp got hot, like over 85-90 deg. Very annoying when you have to sit in a 100 degree car holding the fob against the steering wheel for 3-5 minutes while Honda Accords drive by w/o any problem. Another bimmer "feature".
Old 09-08-2015, 11:06 PM
Thank you for the response- most useful. Still waiting for BMW to have a look- I don't have GPS and just the starting which is a problem and still is even though temperatures are pretty cool-17 degrees C celsius today. Will post outcome later this month.
Old 09-24-2015, 08:04 AM
Today collected the car- all fixed by dealer. Had to pay for a diagnosis which was a faulty Diversity Aerial. They replaced the antenna amplifier and reprogrammed the remotes. Total cost 443. Also had two run flat tyres (now 5 in total in 27k miles) replaced
Old 12-03-2016, 05:39 AM
Nampvi Nampvi is offline
Mein Auto: Bmw 520i
The receiver is Antenna ??
Old 12-05-2016, 04:08 AM
asp535ix asp535ix is offline
Mein Auto: 2011 535i XDrive
Bad Diveristy Antenna
Had the same issue. In the passenger side "C" pillar is the culprit. Replace this bad diversity antenna and problem solved! Good luck!
Old 12-20-2016, 07:11 AM
Mein Auto: Bmw 520i
Do you solve your problem??
I'm having the same problem
Every time I open the door when the car engine is running, then the screen have eror as " Remote control not present or fault. Emgine cannot be stared. See owner'S handbook"
I had replace a Antenna Diversity but not solve this problem.
Please help me.
Old 12-22-2016, 09:13 PM
supkp supkp is offline
I have exactly same problem as Nampvi latest post. remote control not present ... if you open the door while engine is running. Dealer diagnose to the connection E84*1B is backed out from center console aerial
Old 12-22-2016, 10:39 PM
Mein Auto: Bmw 520i
Presently, do you fix this error??
Please show me how to fix it
Old 12-23-2016, 06:05 PM
I took my car to dealer for other problems beside this and this is what dealer documented in the repair sheet.
Old 02-13-2017, 10:49 AM
dannyboycf31 dannyboycf31 is offline
Mein Auto: Bmw m5 f10
Did u get this issue sorted im having exact same thing
Old 02-13-2017, 10:50 AM
How dod u get this issue sorted im having same issue ?
