[Z4MC] Replacing shocks at 40k miles - what else? - Bimmerfest - BMW Forums
Old 06-05-2011, 10:58 AM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '05 330Ci ZHP, '16 Golf R
I have a set of Bilstein HD's sitting ready to be installed (via shox.com), and will have them installed next week, during my first visit to a well-regarded local indy mechanic. The car now has 40k miles on it. What else should be replaced, if anything? Bushings? If so, where? Are stock "good enough" if I've been happy with the original setup? Any guidance appreciated.
'05 ZHP Coupé
'16 Golf R
Old 06-05-2011, 03:07 PM
car62 car62 is offline
Mein Auto: Z4MC AW/IR
Some people would replace the rear trailing arm bushings, also known as toe control bushings, but a special tool is needed for that job. Your independent mechanic might not have the tool. Rear alignment would be needed after replacing those bushings.
Old 06-05-2011, 07:15 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Powerflex makes RTABs for the Z4 and M series, supposed to be painless and squeak free as well. I'd love to hear how the HDs turn out. I'm thinking to do the same.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 02-07-2012, 08:49 PM
KevinC's Avatar
your average JAMF
Reviving this thread because I'm FINALLY getting ready to get the Bilsteins installed. Planning on having the CDV removed, oil changed, and my AC belt checked, which my none-too-helpful stealership told me almost immediately after the 4/50 maintenance expired that it was "cracking". I'll discuss the RTAB's with my mechanic. Any other last-minute suggestions? Thanks.
'05 ZHP Coupé
'16 Golf R
Old 02-08-2012, 07:51 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
You hung in there for 40k miles with the CDV still in place? Brave soul.
Happy motoring.
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 02-08-2012, 09:07 AM
brianrparker brianrparker is offline
Mein Auto: 1997 BMW z3
Happy motoring.
Whats a CDV and why remove it?
Old 02-08-2012, 10:08 AM
Check, Delay Valve. I don't know about the Z3 but in the Z4 it slows down your clutch engagement between 1st and 2nd gears. Makes you do the bobble head no matter what your experiance with a clutch is. From what I have read and spoken with other m owners it is almost the 1st mod made to the car. It made a immediate differenece in the driveablity of my car once it was removed. Some people have pulled them out and drilled out the valve, others bought Zeckhussen's valve. (I did).
VRSF Charge Pipe /
BMWCCA Member
Old 02-08-2012, 04:29 PM
RobMCoupe RobMCoupe is offline
Mein Auto: 2007 Z4M Coupe
Check power steering hose. My have a leak and replace under warranty. It is a known issue.
Old 02-08-2012, 08:51 PM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
Don't forget about those motor mount bolts!
CDV delete, clutch stop, BMW pedals, Strongstrut bar, SS brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, roundel under hood, Intravee II ipod adapter, Homelink, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers…
