Old 06-08-2011, 06:29 PM
rambii rambii is offline
Send a message via AIM to rambii
Mein Auto: 1998 BMW 528i
coolant issue?
I recently got my car fixed, swapped the engine and the tranny. Everything is running fine now but I noticed something that doesnt look normal. When the car is cold in the mornings the coolant level is low, but when the car is cold after driving it the coolant level goes up. what can cause this issue? the check coolant or check engine light doesn't come on.
also, i noticed something else. whenever you drive the car and you accelerate a little hard the car kicks and then it holds the gear, and then when i gas it really hard the abs light comes on and the dash board shakes. what can cause that?
Old 06-08-2011, 06:40 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
The coolant expands when it is warm. If I am not mistaken, your car does not have a coolant level sensor. About the ABS light, you will have to get it scanned and see what codes it is throwing.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 06-08-2011, 06:43 PM
i know that it expands but the coolant level is really low, it's between 3 1/2 to 4 inches below the cold level.
Old 06-08-2011, 06:49 PM
Top it off to the cold mark, and bleed your cooling system.
Old 06-08-2011, 11:10 PM
Doing a /bleed in the bestlinks, I find the following for the OP:
- Bleeding the cooling system (1) (2) (3)
