Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 06-09-2011, 03:32 PM
kellym0062 kellym0062 is offline
Mein Auto: 3 series
645 Convertible Top Problem
I am having problems with my convertible top on my 645. It will not go up or down. The red light flshes on and off. On my dash, it states that the top is not closed, but it is closed.
Damsel in distress. Please help.
Old 06-09-2011, 04:06 PM
TxTaz's Avatar
TxTaz TxTaz is offline
It's hot in Texas
Mein Auto: 2005 645CI Convertible
Welcome to the board.
Is the space for the top in the trunk in the open position?
There is a little handle on the right to pull it down and out. It folds up to give more trunk space but needs to be down to hold the top.
Taz... My favorite BMW so far.
Sport, Cold weather, Logic 7
19" Miro M6 Wheels w/competition stems
MGP Claiper Covers (BMW)
Dension Gateway 500 and Audio Video Router
AC Schnitzer pedals
Carbon Fiber Di-Noc Trim
5W White Angel Eyes
Polk tweeters
Old 06-13-2011, 07:53 AM
spooner30 spooner30 is offline
Mein Auto: 325i
Check this out, probably the same issue I had and many others.
http://www.bimmerfest.com/forums/sho...ht=convertible
Old 06-23-2011, 12:05 PM
Docboy78 Docboy78 is offline
Mein Auto: BMW 645ci
Be sure there are no obstructions in the way of the top box. My briefcase was slightly wedged in there and was causing the error message.
Old 04-16-2012, 11:58 AM
jaycomb jaycomb is offline
Mein Auto: 645ci convertible
I had the same problem as well, i brought it to the dealer they have checked and wanted me to replace the whole top, i said **** that so brought back home and when summer came around it started to work on itself so i found out that the only reason why it did that its because during the winter u don't open and it freezes... Keep tryin' cause i was tryin' everyday until it worked!
Old 04-20-2012, 10:18 PM
Aj645ci Aj645ci is offline
Mein Auto: Bmw 645ci
On the back seat driver side there is a black box with to wires on the soft top u cud side by the back window pull the soft top a lil touch the wire and the back window will go down and the red light will go a away u need to change that it's like a switch for the back window and the trunk won't open cuz off that
Old 07-20-2012, 03:51 PM
BMWBRIAN BMWBRIAN is offline
Mein Auto: 2005 BMW 645CI
BMW 645ci Convertible top problem
ON the back seat drivers side wiggle around the wires on the roof soft top in the back seat. THANKS TO Aj645ci. IT WORKS(FOR NOW)
Old 07-20-2012, 03:52 PM
Thank you
Originally Posted by aj645ci View Post
on the back seat driver side there is a black box with to wires on the soft top u cud side by the back window pull the soft top a lil touch the wire and the back window will go down and the red light will go a away u need to change that it's like a switch for the back window and the trunk won't open cuz off that
this worked))))
Old 07-31-2012, 06:50 PM
Bm Bim Bm Bim is offline
Mein Auto: 2005 645 Vert
The greatest
Heyyyyy a j645....the wiggle of the cord works thanks god cause I was gonna take it to the dealer and waste 300 bucks I will wiggle the wire for now.......Good looking Aj.....
Old 07-31-2012, 07:32 PM
Blinkin light
Hey is there a DIY method to the blinking light on the side of the knob witch turn on the head lights? And what cause the light to blink? the headlights seem to be working perfect.
Old 08-01-2012, 03:33 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2007 BMW 650 vert
Could be that a bulb is about to go out
Regards, Greg
'07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs
'11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Old 08-01-2012, 07:14 PM
Oh ok will just have to wait and see cause some people on here saids it's a module problem of some sort and could cost up to 2000 to fix......I hope this is not the case??
Old 04-30-2013, 01:10 PM
pcpayne71 pcpayne71 is offline
Mein Auto: 2005 645ci
05 645 Convertible Top Problems
I have a 05 645 convertible with 48K miles. I've been having the recurring problem with the drop top as described below. Has anyone had any luck getting any relief from BMW for cars that are out of warranty? It seems to me that this problem is fairly widespread and BMW should step up and take care of the problem for it's loyal customers.
Old 05-01-2013, 01:48 PM
gregb's Avatar
you're probably not going to get any help from the dealer or BMW on the 2005. Even though there is a TSB and they probably should have done a recall, I don't expect that they will.
Best bet is to keep relying on the famous (and now legendary) "Boesman fix" - if it gets really bad or multiple problems, you might be able to talk a dealer service manager into giving you some sort of discount (or maybe goodwill the sensors/parts for free as a long shot).
I've been fortunate and Global has fixed my top a couple of times and covered it under CPO (only $50 deductible).
Regards, Greg
Old 05-04-2013, 05:08 AM
Cibob Cibob is offline
Mein Auto: 645ci
I have the same prob. Flashing red light. As far as I can tell the hydraulics are not locking the back cover. If you can pull it up by hand that is the case. If any one out there knows how to get the system to lock please let me know.hopefully this will complete the cycle and the red light will stop flashing and will be ready to put the top up again.
Old 05-08-2013, 07:19 AM
Convertible Top
After countless occurrences of the mysterious "convertible top not locked" warning, I called my service adviser at Global Imports in Atlanta. He indicated that this is common problem, particularly in pre 2008 models. The solution is to replace the "angle of rotation sensor" and recalibrate / realign the top. This fix cost $360 and so far seems to have done the trick. We'll see what happens when the weather gets hot. I'll keep you all posted.
Old 05-08-2013, 02:52 PM
Mein Auto: 645ci
convertible top
Thanks for the info on the top,I appriciate. I have taken out the inner lining out of the trunk so I can put my hand in to push the locking cam forward to lock the tunnel cover . Now to recalibrate hummmmm wil have to do some more looking around on how to do that.
Old 05-09-2013, 04:59 AM
gregb's Avatar
Yes - Global has fixed the same error on my top a couple of times over the last 2.5 years (fortunately covered under CPO). They do a good job.
Regards, Greg
