Old 06-16-2011, 07:16 PM
redbull713's Avatar
redbull713 redbull713 is offline
Mein Auto: 96 M3 2/5spd
How to test ignition coils? E39 540i M62
I would like to know what the procedure for testing an ignition coil is. What kind of multimeter is good for this?
Old 06-16-2011, 09:30 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
About all you can do is check it with an ohm meter. The spec is in Bentleys, I'm traveling and don't have them with me.
It your a McGiver type you could hook a pulsed voltage up to the input and measure the output on a scope using a large resistor divider network.
The output is probably around 50,000 volts so get your worse neighbor to hold it.
Old 06-16-2011, 09:34 PM
redbull713's Avatar
DAING! Oh well, so i just check the resistance?
Old 06-16-2011, 10:13 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I remember seeing it in my Bentleys also.
But most people test 'em on the vehicle.
- How to check which coil is bad:
Old 06-16-2011, 10:18 PM
bluebee's Avatar
I just checked. The Bentleys (which every BMW owner should have) show how to test 'em on page 120-11 "Ignition System" among other pages.
Old 06-17-2011, 06:42 AM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
Low Current Probe around the ground supply to the coil is How I test them with the labscope.
http://www.amazon.com/Electronic-Spe...317508&sr=1-12
Hickok also makes a handheld COP tester that some of the techs that weren't quite as tech savvy used to quickly identify "the bad one" I never used it but they seemed to have very good results. It's fast b/c it doesn't require any dis-assembly other than pulling the coil covers.
http://www.amazon.com/Hickok-76562-C...ref=pd_cp_hi_3
They will often fail and still pass the resistance test so I don't even bother with it.
Old 06-17-2011, 06:53 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Or you can move it from cylinder to cylinder if you're getting a misfire.. See if it follows.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 06-25-2012, 12:40 PM
jmansour jmansour is offline
Mein Auto: 04 325i -5spd black/black
hey guys I know this is a old thread but im havng a missfire in cyl 2. i tested the coils the hard way () they all work.
the Spark plugs are new. Any more ideas?
2000 540i with 107k miles :/
