E60 (2004 - 2010)
Old 06-19-2011, 03:08 AM
thefatalrisk thefatalrisk is offline
Mein Auto: 525i E60 2006
Exclamation Help! Bizzarre DSC Behavior ?
Hi guys,
I have an E60 2006 525i and I love it. But over the past few weeks the cars electronics play up big time.
Basically what happens is that when I start the car, everything is all fine.
After I have ridden the car a certain distance (very variable, but usually within 15 mins) I suddenly get a whole lot of warning messages:
1. Control systems - brake and driving control systems failure. Drive moderately and avoid hard braking.
2. Active Steering inactive - please stop if possible and restart engine
3. Restrain systems - function of airbags, belt tensioners and belt force limiters faulty. Ensure your seat belt is fastened despite the fault.
4. Cruise control fault - cruise control function faulty.
The washer fluid low message isnt anything new.
Pictures of the above are attached.
All the dashboard lights light up.
My speedometer fails to work.
I lose my power steering - very hard to turn.
I lose cruise control ability.
Braking is less responsive.
This fault remains so until I stop the car and turn off the ignition. After about 5mins I am able to turn the car on with no faults and drive properly, however the fault happens again within 15mins.
I took my car to a private BMW mechanics and they did the diagnostic check on it and they came to the conclusion that there was a fault with the DSC module and that the control unit couldn't communicate with the diagnostic. I have been quoted $1890 AUD for the DSC ECU part alone (ordered from Germany) and $2200 in total (including fitting and a few hours of programming).
Has anyone else come across this problem before? No doubt $2200 is quite a hefty price to shelf-out and I want to make sure that there's nothing simple in the first instance.
Any suggestions would be greatly appreciated.
ID:	282322   Click image for larger version
ID:	282323   Click image for larger version
ID:	282324   Click image for larger version
ID:	282325   Click image for larger version
Old 06-19-2011, 11:14 AM
DRExi22 DRExi22 is offline
Mein Auto: 06' 530xi
Sounds like a dying battery...
Old 06-19-2011, 06:26 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
2200$ for a new DSC?
That's a bit over the top.
We have an E60 and an E39. The E39 DSC fried once in the past but we never experienced this issues. We ended up changing it for 650$ with a second hand DSC
Old 06-19-2011, 09:17 PM
MSAMMY MSAMMY is offline
2007 550i & X3, 2002 X5
Mein Auto: BMW 550i, X5, X3
I agree. Is this the original battery? If so, replace it and start from there...
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon
2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon
2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle
Old 06-23-2011, 07:59 AM
Yes this is the original battery. I have organised for another BMW mechanic shop to independently check it out as well and will get them to try a replacement battery.
Old 06-23-2011, 08:08 AM
phelpha phelpha is offline
Family Man
Mein Auto: 525i
or altenator either way could be one or the other
Old 06-23-2011, 01:00 PM
That's a 5 year old battery. With all of the electronics in the E60, that's about the max timeframe before you'll need to change the battery, so it's time. I would try replacing the battery first, it's well-known that many have seen bogus messages on the Idrive display once the battery got weak.
Old 06-24-2011, 01:59 AM
Had a battery shop check the voltage and crank today. Was running at 12.6V when car off with good crank. Was aroung 13.something when the car was on with light on and a/c full. Would this rule out a battery cause?
Old 06-24-2011, 04:27 AM
SoLucky SoLucky is offline
Nothing to see here...
Mein Auto: '08 535i
In short, no.
As others have said, your battery is end of life. Just replace it. It may very well "fix" your DSC / warning light issue. If it doesn't solve that problem, well then you'll feel better about shelling out the $AU to replace the DSC. If it does solve the problem, treat yourself to a weekend vacation as a way of thanking yourself for listening to your Interwebz colleagues.
Old 06-24-2011, 06:38 AM
Originally Posted by SoLucky View Post
In short, no.
Thanks for the advice. I will do this.
Is any car battery shop able to fit a new battery?
I heard that you need to get the car reprogrammed after you install a new battery.
Old 10-12-2011, 06:13 AM
jamdownMan jamdownMan is offline
Mein Auto: CT9A/525i
Hi all,
My father's 525i is experiencing this very same issue. Was the Original Poster able to fix this by simply replacing the battery?
Old 10-12-2011, 07:36 AM
old-school old-school is offline
Mein Auto: 2004 BMW 545i
Ditto here with having problems with electrical gremlins on my 04 545i. Would love to hear from the original poster? You still there?
“Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.” Albert Einstein
Old 10-16-2011, 06:14 AM
Hello,
Unfortunately no, the battery change didn't do a thing. Eventually I changed the DSC module (which cost me a lot!) and that fixed the problem.
The BMW mechanic gave me back the old/damaged DSC module, its the size of a small book (yet it cost so much).
control module, cruise control, dsc, e60 5-series, ecu
