Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 07-10-2013, 06:05 PM
jpfrog80's Avatar
jpfrog80 jpfrog80 is offline
Officially Welcomed to the 'Fest!
Mein Auto: 2006 325i
Nice write-up! I used to change all the oil on my e46, but the wife always took her e90 in to have it done. Now that I'm driving the e90 I do it myself, but the 2014 X3 we got for the wife a couple of weeks ago won't be due for a dealer oil change for a loooooong time. My mechanic told me to do myself a favor now and change the oil with Mobil 1 every 5k and then take it to the dealer at scheduled intervals. He says go Mobil 1 because it's better than the generic BMW oil (I forget the brand that BMW uses and relabels as their own). He sees a lot of cars after the warranty expires and swears that the extra oil changes outside of dealer intervals will save much hassle after warranty goes in 4 years.
I hadn't heard that changing my own oil between intervals would be bad for the existing warranty...where is this documented? I was very much looking forward to changing the X3's oil since it should be much easier getting under the vehicle than my e46 or e90. I just need her to drive it to 5k miles...at 2 weeks old, it's only 4,437 miles away!
Another question- will using Mobil 1 on my own and having the dealer use the BMW brand cause me any issues? I can't see that it would, aside from the X3 getting used to the better Mobil 1 for 2 of every 3 changes.
Thanks all-
-JPFROG
Former Autos:
2001 BMW 330Ci (sold...miss it terribly)
2006 BMW 325i
2014 BMW X3 xDrive35i
Old 07-10-2013, 10:01 PM
lbjgh's Avatar
lbjgh lbjgh is online now
Mein Auto: 2013 X3 M-Sport
What do you guys think about installing a Fumoto drain valve on their bimmer to speed up oil changes? I use one of these on my motorcycle.
http://www.qwikvalve.com/?gclid=CLWm...FUhgMgodYkoA2Q
Old 07-14-2013, 09:40 PM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
Thanks all-
-JPFROG
BMW's oil is a long way from generic. They use Castrol synthetic, labeled as BMW. I freely substitute store bought Castrol synthetic for BMW synthetic, but have actually found the price for the BMW synthetic less than store bought Castrol in some instances. I use Castrol in my M5 and have 213k miles on my 911SC with regular Castrol. It's the only oil I've used in it for 29 years and the engine has never been opened.
Mobil 1 is also a great choice. You really should check with the dealer first to make sure there are no warranty issues if you switch. Don't give them an excuse to void your warranty if something were to happen unrelated.
As to changing synthetic every 5k mile, I think that's a bit much. I split the recommended mileage difference and just had mine changed at 7k miles. BMW will pick up the tab at the 15k mark. I'll pay again at 22k.
I never had any warranty issues when I changed my own oil. I always bought the filter from the dealer so there was some record, but that's it. However, be careful, the oil pan is aluminum and the drain plug is steel; very easy to strip the aluminum threads. That's why I started using a vacuum to suck out the oil rather than removing the drain plug. Since there's no dip stick tube on the X3, I let the dealer change the X3's oil. You shouldn't have a problem; I'm just being paranoid after stripping my M5's oil pan.
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
Old 04-04-2016, 02:04 PM
w5xz w5xz is offline
Mein Auto: F25, F30
greetings from Texas
Wal Mart had Mobile-1 0w40 Eu spec on sale for $20 / 5 quarts; couldn't resist. My ride is not an 'Ultimate Leasing Machine', so I intend to baby it. 2011 x328i, with only 25k miles on her. Oil change
was easy, that stuff was FILTHY...not a big believer in extended oil changes, myself.
Just for the heck of it ( to test the oil level sensor, mainly ), i only put 6 quarts back in. The dash says the oil level is "FULL"...
what the XXXX ???
(drained and flushed radiator too; also, pretty easy; the bottom hose on the radiator came off easily, anb the electric water pump makes the
'burping' process almost painless)
regards, Dan
