Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 06-19-2011, 06:58 PM
supremeart supremeart is offline
Mein Auto: USA
Bumper Gap/Headlight Alignment 2011 30i
Can anyone post some close up high res pictures of 3 things (preferably on a non black car so can see the gaps).
1) The gaps between the front fender and the front air dam (side)
2) The gap between the hood front and where it meets the front air dam.
3) The tops of the deadlights where they line up with the hood.
Reason being, my front bumper cover and driver side headlight had to be replaced due to a fender bender and there have been many issues lining it up to spec due to the body shop (a BMW body shop BTW) having only repaired one front end damaged Z4 since 2009 (!?).
I think the gaps are too much at the sides and the hood, and the headlight that was replaced seems too far recessed. The headlight that wasn't replaced seems that you can run your finger along the top of the light and it will fit into the gap slightly, on the replaced one, it is further in it appears..
Old 06-19-2011, 07:26 PM
pradeeptempalli pradeeptempalli is offline
Mein Auto: 2011 BMW Z4 30i
I just PMed some pics of the angles you requested. My Z4 is the same color as yours Let me know if you need more.
Last edited by pradeeptempalli; 06-19-2011 at 07:37 PM. Reason: Sent it via board. Couldn't attach pics via PM
Old 06-19-2011, 07:36 PM
Pics of Z4
Here are some pics you requested. Let me know if you need more.
ID:	282398   Click image for larger version
ID:	282399   Click image for larger version
ID:	282400   Click image for larger version
ID:	282401   Click image for larger version
Old 06-19-2011, 07:39 PM
Pics of Z4 Part 2
Part 2.
ID:	282404   Click image for larger version
ID:	282405   Click image for larger version
ID:	282406   Click image for larger version
ID:	282407   Click image for larger version
Old 06-19-2011, 07:41 PM
Pics of Z4 Part 3
Part 3
ID:	282410   Click image for larger version
ID:	282411   Click image for larger version
ID:	282412   Click image for larger version
Old 06-19-2011, 07:56 PM
Mein Auto: USA
Thakk you SO much for the quick reply and the effort. Was actually needing them to show to the body shop tomorrow. Looks like all not so off at all, just my driver's side headlight needs to be repositioned (top edge nearly flush with the hood), but I can see how it is off already now that I look at the mounting screw, because the screw looks off center, so should be an easy fix. :-)
I thought it was a problem the way it "pinches towards the rear of the side gaps, but looks to be the way it is,,
BTW, bet you're happy you went with Mojave. Few brave enough to go with a color that more often than not, they were unable to view in person prior to buying, but all VERY happy (me included)..
Only other color I might have considered, would have been Marrakesh brown metallic had it been available on the Z4, but that's only on the 1. 2nd nicest color BMW makes for any car IMO. :-)
Old 06-19-2011, 08:12 PM
No problem. You posted lots of pics for us to view and also sent me some interior pics for me. I love the Mojave metallic, I get lots of compliments and if I were to reorder this would be my color choice again. It was tough to make up my mind without seeing the color in person. This color looks so different in different lighting conditions. Let me know if you need more pics or videos.
Pradeep
HTML code is Off
