Old 06-20-2011, 11:01 AM
pellaw pellaw is offline
Mein Auto: 1998 Z3 M Roadster
Z3 Newbie Needs Help with Tonneau Cover
First post. Be kind. Just bought a 98 Z3 M - has a tonneau cover that is like new - seemingly never used - and that may be because rather than having the "tenex" (sp?) style stud buttons (which is what everyone seems to describe) for the "front" - this cover has nylon straps with plastic pinch clips - similar to the clips which straps down the wind screen - except wider. The cover itself has the "male" clp ends - but the car does not have the "female" clip receptacles. Cover looks OEM (at least it has instructions in german) - I must be missing something somewhere - if I need some female receptacles for the car -where can I find them? Thanks!
Old 06-20-2011, 11:36 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
never heard of something like that - got pictures?
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 06-20-2011, 05:09 PM
Steamer's Avatar
Steamer Steamer is offline
Mein Auto: 2011 550i, 00 M Roadster
post some pictures of what you have,
Old 06-20-2011, 07:22 PM
Here are a couple of pix of what I have - look familiar to anyone?
Name:	Z3 Tonneau Straps 001.jpg
ID:	282525   Click image for larger version
Name:	Z3 Tonneau Straps 004.jpg
ID:	282526   Click image for larger version
Name:	Z3 Tonneau Straps 006.jpg
ID:	282527   Click image for larger version
Name:	Z3 Tonneau Straps 010.jpg
Old 06-20-2011, 07:56 PM
b-y's Avatar
b-y b-y is offline
Mein Auto: 328xiT & M roadster
I have never seen anything like that, but I MAY have a solution. Those clips are similar to the ones used in the factory optional windblocker. I bought one used, and the elastic was stretched past its useful limits. I bought new elastic and new clips at a camping supply store. The clips did not match perfectly, so I bought complete sets, all slightly oversized.
It looks like you could easily make the missing pieces the same way.
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.)
Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.)
Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue.
Old 06-21-2011, 07:25 AM
Yep, looks OEM but designed to work with the OEM wind screen.
Old 06-21-2011, 07:34 AM
Only one set of "female" snaps in the car - which would mean that it would be either the screen or the tonneau - and that seems weird doesn't it?
And I think the windscreen clips are just a shade narrower than these.
Is there an OEM parts book online where I could check to see if there are companion straps for the car?
Old 06-21-2011, 10:23 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Then again, we have NEVER used the cover on our car. So ignore it.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-21-2011, 11:56 AM
b-y's Avatar
b-y b-y is offline
I found the pix I took when I "improved" my windscreen. This photo has both the original clip and the replacement from the camping supply people.
Old 06-22-2011, 04:06 AM
I should be able to rig something from that - thanks for the lead.
