The X5 SAV Forum
Old 06-23-2011, 09:37 AM
wilopes36 wilopes36 is offline
Mein Auto: BMW X5 4.4, BMW 740iL
Transmission Fail safe, Brake and ABS light
Hello All,
did anyone has any idea on how to solve the proble of transmission fail safe, Brake and ABS light that came on premanently. The light came on on my dash since last week Tuesday, i tried changing the Temperature thermostat but the prob still persist. Kindly help!!!!
Old 06-23-2011, 10:31 AM
petener999's Avatar
petener999 petener999 is offline
Mein Auto: 750i, x5 4.6is, E46 M3
Here you go.
http://www.xoutpost.com/bmw-sav-foru...ther-post.html
http://www.xoutpost.com/bmw-sav-foru...safe-prog.html
Old 06-29-2011, 10:52 AM
Hi peterner999,
Thanks for the reply but the links does not open. I will appreciate if this can be looked into!
Old 07-01-2011, 02:06 PM
petener999's Avatar
Try disconnecting your battery (located in the trunk) for ten minutes and reinstall. If that didn't work, then your alternator need to be replaced. I hope this help!
Old 07-02-2011, 02:10 PM
RachaelsX5 RachaelsX5 is offline
Mein Auto: X5 4.4i
You may want to look at my first post on the site I had a similar issue.
http://www.bimmerfest.com/forums/sho...d.php?t=359915
Old 07-03-2011, 04:03 PM
OrangeGlow21 OrangeGlow21 is offline
Mein Auto: 2005 X5 4.4i--Silver
Happened to my '05 4.4i...alternator had to be replaced. Fortunately it was under CPO warranty...
Mark Howard
President
Old 09-06-2012, 08:04 AM
Naumaq Grabocka Naumaq Grabocka is offline
Mein Auto: 645
ABS light is on, and after 30 miles driving is came on the transmission fail safe. the diagnostic tester says the right rear abs sensor short circuit, i replaced that and still the same. any similar case????
Old 09-14-2012, 02:30 PM
The Trans Fail Safe Problem with the X5 4.4i was resolved by replacing the ABS Module, and by replacing the ABS speed sensor
Old 12-17-2012, 12:14 AM
OzzyX5 OzzyX5 is offline
Mein Auto: 2006 X5 3.0d
Electrical Gremlin
Hi every one, I have a 05 Diesel x5, been a great car till now,
Problems started with seat belt chime coming on with no one in the seat, then all steering wheel controlls stop working, radio stoped working, interior lights staying on, transmision failsafe warning, DSC warning, brake lights stay on, no reverse lights.I have tested many relays, fuses, changed out GM111 to test, removed all dash, glove box, and many othe covers to look for possible wiring problems. I have read in forums that the battery can give problems like this, this problem however is INTERMITANT
Any ideas?
Old 01-11-2013, 09:09 PM
Hi all,
Have found the problem with mine,(05 diesel)
A crook ignition switch.
Apparently a common thing.
