Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 06-23-2011, 03:22 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
DEF with Easy To Use Filler Tube
I stopped by my local VW dealer since the nearest BMW dealer is about 75 miles away. I purchased a 1.89 Liter/0.5 gallon container of AdBlue/DEF. I paid $8.00. It has Mercedes Benz, VW/Audi, BMW Group and Mazda part numbers on the container. The filler tube screws right on to the car and the fluid is quickly drained into the reservoir. My car has 4400 miles on it and it took the complete container. I will go buy bulk DEF over the weekend from the local Pilot Truck Stop so that I can determine how much fluid has been used since I bought the car. This is, of course, assuming that the tanks were filled when I took delivery. Pilot sells the DEF by the gallon at $2.59/gallon.
The BMW part number on the container is:
831 904 41 139.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
1985 M635 Euro
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 06-23-2011, 03:52 PM
johntube johntube is offline
Mein Auto: 2011 335d w/MSport
Thanks on the post, this will save me (and others) time and possible aggravation when it comes time to add DEF. Thanks again.
Driving something fast....and efficient
2011 335d w/MSport | Alpine White | Black Dakota Leather | Glacier Silver Alum Trim | Premium Package | Cold Weather Package | Paddle Shifters | Steptronic | 193M style wheels!
Old 06-24-2011, 04:59 AM
KarlB KarlB is offline
Mein Auto: 11 335d,08 K12GT,10 S1000
I just filled my 2011 f250 wuth def for the first time, put in 5 gallons (it was almost empty) used a full tank of it in 4200 miles. but that was hauling trailers for almost all of those miles. guess I will get a sperate fuel can for buying def in bulk as the local auto parts store had 2.5 gallon jugs of it for 12.95 a jug so double the price you found.
11 335d
2010 S1000RR
08 K1200GT
08 WR250R
Old 06-24-2011, 07:48 AM
AZDrPhil AZDrPhil is offline
Mein Auto: 335d now gone
Please verify that you stuck the AdBlue bottle into the filler tube on the bottom, i.e the one closest to the ground. Does it look like you'll be able to refill that bottle with bulk DEF?
Old 06-24-2011, 07:56 AM
Addicted2Torque Addicted2Torque is offline
Mein Auto: Depends
the bottle from VW stores that OP describes is identical in form (not price) to the ones from BMW (although I found that few dealers in the DC area stocked the 1/2 gal bottles). I have saved the empty bottles, and intended to figure out how to remove the top to allow refilling them. I did hear reports earlier this year that NAPA had asked dealers to pull 2.5 gal DEF from the shelves due to a problem with contamination. It has me a little concerned about pursuing the cheapest bulk DEF options. VW dealer near me was selling it for $12, funny I also learned that the 4 cyl TDI's don't require DEF, it's only the v6 in the SUV.
335d 2011 BSM/black M-Sport/PP/Nav/HS/CA/HK (ED May 2010)
ordered by Joern @ Passport
Primary Torque Movers:
2011 Ford F350 400HP + 800 Ft Lbs
2009 Formula SS 2x375HP + plenty but unpublished
1999 Dodge Viper 460HP + 500 Ft Lbs
Old 06-24-2011, 10:49 AM
rmorin49's Avatar
Correct. I added th DEF to the bottom as it was marked with a blue label that said refill. Yes, you can remove the cap and refill with bulk DEF. I called the local Pilot Truck Stop and they sell it by the gallon for $2.59/gal. I have a 2.5 gallon tote that I will fill tomorrow.
Sent from my iPhone using BimmerApp
1985 M635 Euro
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 06-24-2011, 11:42 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
The parts store near me will let you order it in 55 gallon drums. Actually I think some size even bigger than that. Probably a good avenue to take for people who use a lot of it.
Sent from my iPad Nano
--Aaron
Old 06-24-2011, 12:15 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Perhaps BMW will put a 55 gal drum on a little trailer behind the X5 and be able to claim a "Lifetime Fill," as they have done with some other fluids.
Old 06-24-2011, 12:28 PM
Your dealer did not tell you about the baby trailer with DEF option?
I could see how buying a drum would work out for the same people who own tanks for diesel storage. Basically people on farms from my experience.
--Aaron
Old 06-24-2011, 12:40 PM
taibanl taibanl is offline
Mein Auto: 335d (e90)
Just curious...why are you feeling the need to top off @ 4400 mi?
Old 06-24-2011, 01:47 PM
E90 Enthusiast E90 Enthusiast is offline
Yikes, is this something I need to worry about? I assumed this would be covered as part of BMW's routine maintenance program.
6/17/13 ED - 328i xDrive Mojave Sedan
5/5/11 ED - 335d Space Gray Sedan
8/30/08 ED - 335i Montego Blue Coupe
9/13/05 ED - 325i Sparkling Graphite Sedan
BMW CCA #366798
Old 06-24-2011, 02:18 PM
rmorin49's Avatar
I am curious to calculate how much is being used in order to see if I would be able to go as long as my scheduled BMW service. It is a pain to go to my dealer as it is about 75 miles away. If I have to add some DEF between oil changes and other services, fine with me.
1985 M635 Euro
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 06-24-2011, 02:20 PM
rmorin49's Avatar
They will fill your DEF tank but only as part of the scheduled maintenance. Some have been successful in getting their dealer to add fluid if they run low but I don't want to have to drive 150 miles just to get a few gallons of DEF, I'll do it myself and then have them fill my tanks when they do a covered scheduled maintenance.
1985 M635 Euro
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 06-24-2011, 03:52 PM
Understood sir...FYI according to a technical contact with BMW NA with whom I spoke this week
The 335d should 'always make 13-15k between DEF fills'. If folks are falling short of that it likely indicates an issue that is covered under warranty.
So its great that we are pursuing alternatives to having to buy the expensive BMW PNs; however, many are getting stuck on the hook for topping off fluid when they should not need to.
Old 06-24-2011, 04:14 PM
I wonder for what type of driving that range is figured out for. Seems the harder someone is on a DEF equipped diesel the more the DEF is used. Or really the more they press the "go" pedal.
--Aaron
Old 06-24-2011, 06:06 PM
This is true. But the harder you push your D, the sooner your service interval will be also. Nevertheless i dont think the relationship is linear
The contact at BMW NA specifically said it should be quite unusual for a 335d to fail to make it to the normal service interval without needing a fill. He said the x5d, might...might...need a top off if doing a lot of heavy towing
Old 06-24-2011, 06:07 PM
Sorry about the double negative... It should make the service interval without needing a fill
Old 06-24-2011, 06:17 PM
My comments on usage were based on what I see on the truck forums. Seems harder you push those the more DEF is used. Whether the CPU on the BMW drops the oil change interval enough or not is beyond my knowledge. I do know that my car ate up it's DEF a good bit before the oil mileage interval but did happen when I hit the yearly.
--Aaron
Old 06-24-2011, 06:24 PM
autoJeff's Avatar
autoJeff autoJeff is offline
driving a D around RTP
Mein Auto: 335d
Interesting statement. I've fallen short multiple times.
Old 06-24-2011, 06:49 PM
When I fell short the entire reaction from te dealer was that of this happens. But maybe they just put up a good act.
--Aaron
Old 06-25-2011, 06:54 AM
Alpine300ZHP Alpine300ZHP is offline
East Coast Commuter
Mein Auto: M3/x5M
831 904 41 139.
Thanks a million for this tip. Do I just go to VW and ask them for the ad blue half gallon bottle? Or do I need to call it something specific?
~ 13 M3 coupe "new" daily beater
~ 13 x5M Hers
- Previous BMW's - Way too many to list here (15)
Old 06-25-2011, 07:42 AM
DnA Diesel DnA Diesel is offline
Mein Auto: E90 335d, Mk4 Jetta TDI
Nope, that's it...KRUSE makes the bottles for all the German OEMs.
Kruse N.A. sells AdBlue direct to consumers on Ebay (link), four 1/2 gal bottles for $25.
Regards
D.
2009 335d Sport - Space Grey, Gloss Black on Black Leather (pics)
Old 06-25-2011, 02:00 PM
mecodoug's Avatar
mecodoug mecodoug is offline
Mein Auto: '11 335d
Fitst time around I made it to 13K service with no DEF warning. I got the warning Friday at just under 21K, so assuming I had 1000 miles left I would have gotten a total of 9,000 miles out of whatever they filled at my initial service. I dumped 1 bottle in like the OP and the warning went away, though I don't think that will be enough to get me to the 26K '2nd' service.
I used the OEM BMW bottle, which seems just like the VW and Kreuse. I have to take a good look to see if I can refill it. If not, I may just cut the bottom off and use it as a funnel. There is a Pilot near here that sells 2 1/2 gallon jugs I think for around $12.
I suppose there is some chance that my transfer system between active and passive is messed up - will report the issue when I go in.
Hers: 2011 VW Golf TDI DSG Loaded
Mine: 2011 335d 6/28/10 ED Tasman Green/Saddle, ZPP, ZSP, ZCW, Nav, H-K audio, paddles, CA
Mine #2: 2012 Ford F-150 XLT 4x4 V6 'Ecoboost' twin turbo boat puller dump runner
Sold: 2006 330i Silver/Black MT, ZPP, ZSP, ZCW
Old 06-25-2011, 02:48 PM
rmorin49's Avatar
Yes, my dealer stocks both the 1/2 gallon bottle with the refill tube and a 2 1/2 gallon jug without a refill tube. Just ask for DEF in a 1/2 gallon bottle. It should run about $8.
1985 M635 Euro
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 06-25-2011, 02:51 PM
rmorin49's Avatar
Regards
D.
OK, but the shipping is $24.44 so this means you are paying over $12 for each bottle. I bought mine for $8 from the VW dealer. You only need to buy one of the bottles with the refill tube and then just refill it with bulk DEF at less than $3/gallon. It's available at virtually all big truck stops. I know for sure the Pilot near me sells it for $2.59/gallon. I'm going to buy 5 gallons tomorrow.
1985 M635 Euro
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
HTML code is Off
