Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 02-21-2012, 06:50 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Originally Posted by dnaer View Post
I thought people from the Pacific NW eat granola, drive Subaru's and only wear Patagonia/NorthFace. You must not be a local
I have a Patagonia fleece coat, 3 pairs of NorthFace Hyvent ski/sb pants. I hate Subies for some reason, and don't eat granola. I *do* wear REI long johns/base wear items, have a 6-digit REI membership number (my wife's # is lower). I have two chain saws and a log splitter.
I was born and raised in WA state - never lived anywhere else!
Old 02-24-2012, 01:15 PM
FlyingLow78 FlyingLow78 is offline
Driving on instruments
Mein Auto: '11 E92 M3
I've got almost 7K on my 'd and I topped up the DEF this evening. I removed the lower cap on the tank (the one marked with the green label that said "DEF Fill" or something) and, using a funnel, I poured my DEF in very slowly from a 2-gallon jug. After less than 1 gallon, it started spewing fluid. Should I not try to fill the other tank? Am I only adding to the active tank? Seems to me it should have taken a lot more.
Old 02-24-2012, 01:30 PM
listerone listerone is offline
Mein Auto: 2011 MB E350 Bluetec
My attitude is to wait for the warning light.That's what I'm doing with my Bluetec...almost 12K miles and no warning yet.I assume that's because 90% of my miles are driven at a steady 70mph.
Do you folks in Blightey have the "free" maintenence like we do here? If you do it seems that waiting for the light or for a routine maintence visit would be the most logical choice.
Currently:2011 MB E350 Bluetec / Palladium Silver / Nav / Active Cruise / HarmonKardon Logic7
Formerly:2009 335d / Monaco Blue / Beige Leather / Nav / iDrive / Xenon / Sirius / HD Radio
Old 02-24-2012, 02:49 PM
dnaer dnaer is offline
Mein Auto: 2010 335D/2012 Wrangler
Originally Posted by cliffj View Post
I topped off the active tank, and put the remainder of the 2.5 gal in the passive tank. .
Interested in how you filled the passive tank.... was it through the upper port?
Vehicle History:
VW Touareg V10 TDI
Hummer H3
Audi S4
Audi A8
Toyota 4 Runner
Nissan 300ZX Turbo
Mercedes 300E
GMC Jimmy
Triumph TR6
Old 02-24-2012, 04:47 PM
dunderhi's Avatar
dunderhi dunderhi is online now
0-60 in 4 secs or less!
Mein Auto: '13 X5M, 650xi
Yup
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link
2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret)
Old 02-25-2012, 11:43 AM
stan01 stan01 is offline
Mein Auto: '10 E90 335d
Will this work?
Buy 1 BMW bottle. Empty into car.
Cut hole in bottom of bottle when empty and fill with cheaper DEF from another source using funnel.
Cover hole with duct tape and empty into car. Repeat as needed.
2010 E90 335d
European Delivery: 12 April 2010
Platinbronze | Oyster/Black | Sport | Premium | iDrive | Logic7 | iPod | Comfort Access | Shades | Folding Seats
Old 02-25-2012, 03:33 PM
dunderhi's Avatar
Originally Posted by stan01 View Post
Will this work?
Or you can just use the funnel to pour into the car.
Old 02-25-2012, 07:01 PM
Will this work?
It might work,I've never tried it but some have done so.What I *know* will work is: get a 1/2 gallon bottle (with the special filler) at a VW dealer
Empty it into the DEF tank
Then cut near the crimp area of the blue part of the bottle (the crimp is all that keeps the blue adapter from being removed),the blue part will then easily screw on and off.
Repeatedly refill that bottle from a 2.5 or 5 gallon jug without special adapter (quite cheap).
Success
Old 02-26-2012, 05:36 PM
cliffj cliffj is offline
Mein Auto: 2011 BMW 335d
dnaer - like dunderhi stated "yup". Active tank on the bottom and passive on the top. My understanding is that the active tank is approx. 1.5gal, and Passive approx. 4.5 gal. In BMW's documentation, it states that the active tank will transfer from the passive when approx. 3 liters are used from the active. I had a total of 3 gallons of DEF. 1/2 gal BMW bottle, and 2.5 gal jug from Autozone. The active tank took a little over 1/2 gallon, and I just put the rest in the passive tank. I probably didn't' completely fill both tanks with only 3 gallons. I had about 900 miles remaining on the low DEF warning indicator. I suspect it will take 4-5 gallons to completely fill both at that point.
There are pro's and con's of using a funnel vs. re-using a modified BMW or VW bottle. I have only tried using the 1/2 gal BMW bottle by continually refilling and screwing onto the fill port of the car. The advantage of this method is that it is easy for one person to fill the tanks by supporting the weight of the bottle with your hands so it doesn't stress the connection point. Also, once the tank is full, the bottle will stop draining and you can simply unscrew the bottle adapter and remove without any spillage. The BMW bottle will close the fill port of the bottle when you unscrew it from the connection point. The disadvantage of this method is that it will probably take slightly longer to fill the tanks. Now that I have done it once, it should only take about 15mins to top both off. Not a big deal at all.
11 335d Sapphire/BLK/M-Spt/HK/6FL/I-drive/SIRIUS
Old 02-27-2012, 06:44 AM
Thanks Cliff.... very helpful. Was going to do it this weekend but went skiing instead; that was an easy decision to make. Bought two 2.5 gallon jugs and will give it a go this coming weekend.
Vehicle History:
VW Touareg V10 TDI
Hummer H3
Audi S4
Audi A8
Toyota 4 Runner
Nissan 300ZX Turbo
Mercedes 300E
GMC Jimmy
Triumph TR6
HTML code is Off
