E36 (1991 - 1999)
Old 06-25-2011, 12:56 AM
kenand1988 kenand1988 is offline
Mein Auto: 1999 323is
Sorry but I just gotta beat this dead horse
Hey all,
I have browsed this forum and others ever since I got my fern green 99 323is in 2007. I can not describe how happy I have been with this car. I have done a few simple things, shark injector, short shifting kit, poly bushings f&r, k&n air filt (not cai). Awhile back when I first got this car I wanted to do a full exhaust and wound up ordering an e46 borla exhaust and then had to send it back. I later learned that as far as aftermarket exhaust options go for the 323is I was pretty limited so I gave up for awhile. Well I am interested in it again and yes I have read many many many threads and I dont need to be explained why my exhaust is different from the 325's on up to the m3's.
What I plan to do for my exhaust is build a custom exhaust from the headers back. Instead of going to a dual pipe dual cat operation I want to keep it single but go up in pipe diameter from 2.25 to 2.5in all the way back to the muffler. I'll also be putting in a high flow cat and new muffler as well. This is cheaper than having a shop build the dual pipe design and lighter than a used 328 or m3 midpipe and muffler.
What can I expect from this? Will it sound horrible? The new cat will supply good back pressure so I don't believe I will lose any torque. I just haven't seen or heard of anyone doing this so I did not know if this was idiotic. It's all going to cost about $500. I also plan on doing the M50 manifold swap.
Thanks in advance
Old 06-25-2011, 04:46 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Your "custom" exhaust will be more restrictive than your stock exhaust. The combined cross sectional area of two 2.25" pipes is 7.9". The cross sectional area of a single 2.5" pipe is 4.9". You'd need to go to 3.125" pipe to get roughly the same cross section.
What you are going to get for your $500 is something that makes your car run worse, but it will be loud.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 06-25-2011, 09:45 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Also, you can bolt any E36 OBD2 6-cylinder exhaust up to a 323, so your choices are not "limited". There is no need to fabricate something yourself.
1998 BMW 328is
1966 Pontiac GTO
Old 06-25-2011, 11:26 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
I have the dual exhaust you want from a 328is Bolt that bad boy on and you'll be good to go
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 06-25-2011, 12:04 PM
UPDATE: I did some more digging and 2.5in seems to be optimal for an n/a 6 cylinder. Even though the 325's,8's, and m3's run dual 2in the dual setup creates more drag.
I will probably lose around 50lbs by replacing the full stock exhaust with a single 2.5in pipe all the way back.
I just can't decide what muffler to go with.
all this info can be found here
http://forums.bimmerforums.com/forum/sh ... 354&page=3
There are even some clips of a guys 2.5 single exhaust on his m3 with a borla muffler.
Old 06-25-2011, 12:47 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Yeah, exhaust is simple stuff.
The stock Catback for E36's weighs 49 pounds.
An aftermarket catback usually weighs around HALF of OEM.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 06-25-2011, 12:51 PM
Hellawut??
Mein Auto: who knows?
^^ 404 not found
-Franklyn
Old 06-25-2011, 01:33 PM
http://forums.bimmerforums.com/forum...d.php?t=910354
Old 06-28-2011, 02:35 PM
A white m3 A white m3 is offline
Mein Auto: 98 ///M3
I have the m50 manifold if your interested.
TRM
Old 06-28-2011, 04:13 PM
this was an attempt to upload pics but it didnt work, ill try again
Old 06-28-2011, 04:33 PM
view from the rear
If you have any questions ill be happy to answer. This was done by someone who makes racing exhausts for e36's. My exhaust is basically a racing exhaust with a resonator.
I'm working on getting a good soundclip up but my phones microphone wont pick up the low notes.
Old 06-28-2011, 06:43 PM
wawaiki wawaiki is offline
Here to learn
Mein Auto: 325is
it will burn your plastic around the tip. what brand is the muffler? And yes please for the video with resonator
Old 06-29-2011, 03:24 AM
projectXe36 projectXe36 is offline
Sittin In The Driveway
Mein Auto: 95 325i
Im thinking of doing something similar with my 325i. I was thinking of running 3" after the headers all the way back to a muffler no cats... Still playing with the idea so idk well see. Id love to hear how yours sounds
Old 06-29-2011, 09:09 AM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
Did you even read the thread?
A 3" exhaust is overkill.
Old 06-29-2011, 09:14 AM
ZeGerman's Avatar
Warm Leatherette
Nevermimd the fact that he's in California and wants to delete his cats... Wonder how that will go...
1998 BMW 328is
1966 Pontiac GTO
Old 06-29-2011, 10:03 AM
Here is a link to a video i shot last night of me starting it up and revving it a little, i apologize you can't really see much though. If you play this through some nice speakers with a sub you get the real idea.
Also, for whoever asked the muffler i believe is part #12258 from magnaflow, it doesn't have a special name.
Old 06-29-2011, 10:07 AM
3inch and no cats might not be a great idea.
Old 06-29-2011, 10:28 AM
ZeGerman's Avatar
Warm Leatherette
orly?
1998 BMW 328is
1966 Pontiac GTO
