Old 06-25-2011, 08:39 PM
cyanfalcon cyanfalcon is offline
Mein Auto: 535 XI
How to Start Car Not Inserting Key 2008 535 XI
I did it one time before and from what I'm reading it seems pretty simple but I can't replicate it again. My car has a start/stop button and my key is right next to me. I press the break and hit the button and nothing happens. I then just insert the key and press the break and hit the button and the car starts. Anyone have any suggestions?
Old 06-25-2011, 08:46 PM
bimmerstien bimmerstien is offline
Mein Auto: 528xi, w/Spt, Nav, PP, CW
Cool
I can start the car with the fob in my pocket. Have you checked your fob battery? I think its a CR25 but confirm this with the Forum.
Old 06-25-2011, 10:29 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
Do you have comfort access? I don't but if I turn off the car, remove the key and immediately press the brake and hit the button, the car will start again. That seems to be a flaw in all E60's without comfort access. I'm not sure if that's what you are referring to.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 06-26-2011, 03:09 AM
Mein Auto: 535 XI
It didn't open when I walked up to it and I can't tell about the groves on the BMW 535 XI so I'm trying to see if the remote has batteries in the back that are dead. I press the button on both remotes but the thing won't open. So frustrating, I feel like I'm breaking it.
Old 06-26-2011, 07:43 PM
MachtSchnell's Avatar
MachtSchnell MachtSchnell is offline
Mein Auto: 2008 535
If you have comfort access you will be able to replace the battery from what I have read. I have comfort access and just had to replace the battery. Was getting a message on the dash saying the battery was dead. Non comfort access have a rechargeable battery and can't be replaces with out breaking the seal on the fob.
Sent from my iPhone using BimmerApp
Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | ALP Jammers w/BT | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads |
Old 06-28-2011, 06:57 AM
X308Black X308Black is offline
Mein Auto: x3 3.0si
I too have to stick the key in the ignition. Is there something I can do to make it where I dont have to stick it in to start? I dont believe I have the comfort access.
Old 06-28-2011, 11:18 AM
2chill's Avatar
Unless you can find an alarm company who can install a remote start alarm in your car, which I highly do not recommend due to the sensitive electronics of BMW's, there is nothing you can do to start an E60 without inserting the key if you do not have comfort access. Going to BMW to have comfort access installed is also probably cost prohibitive.
Old 09-04-2012, 02:46 PM
lesaint0269 lesaint0269 is offline
Mein Auto: 2008 528 Xi
I have the same problem I press the start/stop button without the remote in NADA I put the key in start the car turn the engine off take off the key press start button and the engine start. this is frustrating. How do I know I have Comfort Access can anyone help please
Old 09-04-2012, 03:48 PM
Mein Auto: 535 XI
You likely don't have it. If you have the key out and step on the brake and nothing happens when you press start you most likely don't have it. If you approach your car and the car doesn't unlock you most likely don't have it.
Mine will do it, but I have to start the car with the key in, stop the car and then it will work without the key in it if I do it within 15 seconds. To me that's pointless unless you are one of those people that have a thousand keys on your key ring.
Old 09-04-2012, 04:25 PM
Mine does start within 10 to 15 second but its pointless to start the car turn it off then keyless start it but thanks for the reply and no it doesnt unlock the doors when I approch the car
Old 09-04-2012, 06:11 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
It's easy to know if you have comfort access.
Comfort Access keys have a cover in the back of the key fob so you can replace the battery, Non Comfort Access keys have no cover in the back of the key fob because the battery is rechargeable through the key slot.
Look at this image for reference, if your key looks like the one on the left then you have Comfort Access, if it looks like the right one then you don't have Comfort Access.
Old 09-06-2012, 03:31 PM
bighead2267 bighead2267 is offline
Mein Auto: E60 with a turbo
sorry to jack your thread but do you need to reprogram after you replace battery on the key?
Old 09-06-2012, 06:19 PM
SBC530I SBC530I is offline
Mein Auto: '07 530i, '04 Silverrado
Just replaced battery in my 2007 530i fob and did nothing further to make it work. I have 'comfort access'
Option code S322A KOMFORTZUGANG Comfort Access if you have option list for your car.
Go here http://www.rubmw.ru/vincode/eng/ to get option list for your car by entering the last 7 characters of your VIN.
Old 09-06-2012, 06:22 PM
Yes. I have that option. Will try to find DIY for replace battery.
Old 09-06-2012, 07:07 PM
You should have a key fob that looks like the one on the left - see picture above.
Push down on the ridged part of the fob and then pull towards you. A key will
come out of the fob. You will see a piece of plastic pointing towards you - looks like a fob tongue. Just above it is a slot into which a small blade screwdriver can be placed. Carefully pry up and the battery cover comes off. Replace the battery, then the cover, then the key and all should be well.
Old 09-06-2012, 07:11 PM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Cool URL...http://www.rubmw.ru/vincode/eng/
Old 09-06-2012, 08:02 PM
Thx for sharing
Old 09-06-2012, 08:52 PM
Mein Auto: A Car
Yeah, it's the only BMW VIN decoder that i've seen that works like a champ.
