E46 (1999 - 2006)
Old 06-30-2011, 12:08 PM
kapadiab kapadiab is offline
Mein Auto: 325I
Help on buying code reader/reset
I have 2003 BMW 325I. "Service engine soon" light came on today. I wanted buy code reader/reset, but not sure which one will work best with 2003 BMW 325I. Any suggestions. Thanks for help.
b.k.
Old 06-30-2011, 01:37 PM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
b.k.
Maybe it will be best to take it to a reputable independent shop, that has all the diagnostic equipment. After all, generic readers dont do much, specialist diagnostic are expensive, (ok there are copies around) and they take some time getting used to them, before you will know exactly what you are doing.
Old 06-30-2011, 04:31 PM
Y2K_Bimmer Y2K_Bimmer is offline
Mein Auto: 2000 323i
Harbor Freight has a code reader for $89. I bought one and it read / the codes fine. It will also work on most other cars. Won't reset the airbag and the expensive readers at the dealer give them more information. But, your likely to find an explanation of the code you have right here using the search function.
Old 06-30-2011, 05:54 PM
catso's Avatar
catso catso is offline
catso
Buy a Peake. They read codes that are specific to BMW's.
![/I][/FONT]
Old 06-30-2011, 07:35 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
A quick /scanner in the E39 bestlinks nets this $22 tester that many of us use:
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Of course, there's always freeware (but you still need the cable):
- OBD II PC freeware & $15 J1962 cable for the BMW E39
Old 06-30-2011, 07:38 PM
bluebee's Avatar
In addition to the inexpensive stuff, a quick /scanner in the bestlinks nets these more expensive scanners.
- How to diagnose a typical BMW E39 engine misfire (1) & where to get the cheapest reasonable OBDII scanner in the world (1) (2) or a better overall scanner (1) or the best BMW diagnostic tools (1) (2) (3)
My suggestion?
Compare whatever you want with the 22-dollar scanner for the things that you care about.
For me, I'll buy a more expensive scanner when I need it - but - so far - I haven't needed it (100K miles).
Old 06-30-2011, 10:02 PM
Mein Auto: 325I
Smile
thanks to everyone, I will look into this. I like $22 scanner.
I will go to Harbor freight store nearby my house and comapre with this @22 scanner.
Thanks to all
bk
Old 06-30-2011, 11:12 PM
Steelcitybeemer Steelcitybeemer is offline
Liebe mein bimmer!
Mein Auto: 2003 325i
I use an Equus 3100 scanner. Works very well and easy to use.
2003 325i... Stay easy
Old 07-05-2011, 09:28 PM
Mein Auto: 325I
Hi all,
I ordered autel maxiscan ms300 code reader from Amazon. . I think at this point, this will good for me and cheap. Equus 3100 is good too.
Once I read the code, I will let you know.
Bluebee, good sugestions and advice... this is what I was looking for.
bk
Old 07-22-2011, 01:34 PM
Mein Auto: 325I
hi Bluebee,
Received maxiscan ms 300 and checked the code. The code was P0455. Clear the code and checked the gap cap. so far so good no code... driven 200 miles. the cap is good condition and I was not smelling any gas, so I decided not to replace cap and drive some miles and see if I get any code. so far no service engine light and codes
This scanner is not fancy, but for the price it is well worth it to have it. Saved $100..... Thanks Bluebee and others who helped me.
bk
Old 07-23-2011, 09:22 AM
MRHEAT MRHEAT is offline
Mein Auto: 325i
PEAKE is the way to go real easy resets for oil changes, inspections, and trouble shooting
Old 07-23-2011, 08:06 PM
Mein Auto: 325I
hello Mrheat,
I can't isagree with you, but I reset service reminder without any tools in 2003 model, I needed only code sanner which I can use for other cars also.
Thnaks
bk
Old 07-24-2011, 12:26 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
BLUEBEE, how about this tool?
******** type=text/javascript src="http://include.ebaystatic.com/v4js/z/yw/n5h3wmxgey0ypgi1xpfwz5zf2.js#SYS-ZAM_vjo_e731_1_13532468_en_US_AUTOS">*********>******** type=text/javascript>vjo.dsf.error.ErrorHandlerManager.register(new vjo.dsf.error.DefaultErrorHandler());vjo.dsf.error .ErrorHandlerManager.enableOnError(true, false);*********>********>var ebayItemID=280676749366;var ebayItemRevisionTime=1302620112000;var ebayAskSellerURL='http://contact.ebay.com/ebaymotors/ws/eBayISAPI.dll?ShowSellerFAQ&frm=284&iid=280676749366&ssPageName=PageSellerM2MFAQ_VI&redirect=0&requested=tsgeorge2011';var bStoresNav=false;*********>******** type=text/javascript> var sUrl = "http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItemDescV4&s2=0"; vjo.ctype('vjo.darwin.pres*****ing.cmp.iframe.Aegi s').needs("vjo.dsf.client.Browser").props({ebayAegis:function(){window.setTimeout=fu nction(pFunc,pStart){};window.setInterval=function (pFunc,pInt){};},setHash:function(){var bSafari=vjo.dsf.client.Browser.bSafari||vjo.dsf.cl ient.Browser.bChrome;var re=new RegExp("^http\://cgi\.");var re2=new RegExp("^(http\://www\.)([a-z]{2}\.)?([0-9a-z]{5}\.)?([a-z]{2}\.)?([a-z]{4}\.)([a-z]{3}|[a-z]{2})(\.[a-z]{2})?(/itm/)");var re3=new RegExp("^http\://vi\.");var rf=window.document.referrer;if(bSafari){if((rf.toS tring().match(re)!==null)||(rf.toString().match(re 2)!==null)){parent.location.replace(rf+"#bl");}}else{if(rf.toString().match(re3)!==null){paren t.frames[0].location.replace(sUrl+"&c=1#bl");}}},process:function(piTime){var img=new Image();var oCl=vjo.dsf.client.Browser;var browser,os;var bl=new Date().getSeconds();if(oCl.bWebTV){browser="webtv";}else if(oCl.bFirefox){browser="firefox";}else if(oCl.bSafari){browser="safari";}else if(oCl.bChrome){browser="chrome";}else if(oCl.bOpera){browser="opera";}else if(oCl.bNav){browser="netscape";}else if(oCl.bIE){browser="msie";}if(oCl.bWin){os="windows";}else if(oCl.bWinXp){os="windows xp";}else if(oCl.bVista){os="windows vista";}else if(oCl.bXpSp2){os="windows xp sp 2";}else if(oCl.bMac){os="mac";}else if(oCl.bMacppc){os="mac powerpc";}else if(oCl.bMactel){os="mac intel";}window.onerror=function(message,url,line){if(typ eof(window.iErrorCt)=="undefined"){img.src=errorLogUrl+"&item="+ebayItemID+"&difJserror=1"+"&difJserrorDesc="+message+" on line "+line+"&bs="+browser+" "+oCl.fVer+"&os="+os+"&seller="+sellerId;window.iErrorCt=1;return true;}};if((typeof(piTime)!==null)&&(typeof(window.iErrorCt)=="undefined")){var lt=(bl-piTime)/1000;if(lt>clientErrorThresholdTime){img.src=errorLogUrl+"&item="+ebayItemID+"&difUrlResp="+lt+"&bs="+browser+" "+oCl.fVer+"&os="+os+"&seller="+sellerId;}}}}).inits(function(){if(typeof(clientE rrorLog)!=="undefined"){if(clientErrorLog){vjo.darwin.pres*****ing.cmp.i frame.Aegis.setHash();vjo.darwin.pres*****ing.cmp. iframe.Aegis.process(null);vjo.dsf.EventDispatcher .addEventListener(window,"unload",function(){window.onerror=null;});}}}).endType(); *********> *******>*******>********>********>
******** type=text/javascript> vjo.ctype('vjo.darwin.pres*****ing.cmp.iframe.Aegi sDescription').needs('vjo.dsf.EventDispatcher').pr ops({constructs:function(){var t=this;t.lastInitCall="";},init:function(callerId){var t=this;t.lastInitCall="";t.bSafari=vjo.dsf.client.Browser.bSafari||vjo.dsf .client.Browser.bChrome;t.bFirefox=vjo.dsf.client. Browser.bFirefox;t.iVer=vjo.dsf.client.Browser.iVe r;t.bWin=vjo.dsf.client.Browser.bWin;t.cTime=new Date().getTime();if(!window.bError){var el=new Date().getSeconds();var lt=(el-window.bl);if(typeof(clientErrorLog)!=="undefined"){if(lt>clientErrorThresholdTime){vjo.darwin.pres*****ing. cmp.iframe.Aegis.process(lt);}}}if(((callerId!==2)&&(t.lastInitCall!=='')&&((t.cTime-t.lastInitCall)<2000))||(t.bSafari&&(callerId==1))){return;}t.lastInitCall=t.cTime;var a=document.links;for(var i=0,al=a.length;i=523){w=document.body.scrollWidth;}else if(oCl.bChrome){w=document.body.scrollWidth;}else{ w=document.body.offsetWidth;if(window.scrollMaxX!= =0){w+=window.scrollMaxX;}}}if(isNaN(w)){w=0;}if(( oCl.bFirefox&&oCl.bWin)&&(h>32000)){h=32000;}rv[0]+=h;rv[1]+=w;return rv;},resizeIt:function(callerId){var t=this;var bSafari=vjo.dsf.client.Browser.bSafari||vjo.dsf.cl ient.Browser.bChrome;var size=t.getSize();if(size){if(!bSafari){var rfr=window.document.referrer;var re=new RegExp("^http\://cgi\.");var re2=new RegExp("^(http\://www\.)([a-z]{2}\.)?([0-9a-z]{5}\.)?([a-z]{2}\.)?([a-z]{4}\.)([a-z]{3}|[a-z]{2})(\.[a-z]{2})?(/itm/)");var rf=parent.vjo.darwin.pres*****ing.cmp.userdescript ion.UserDescriptionResizeFrame;if((typeof(rf)!="undefined")&&(rf.toString().match(re)!==null)||(rf.toString().m atch(re2)!==null)){rf.resizeFrame(size);}}t.setDat a(size,callerId);}}}).inits(function(){var bFirefox=vjo.dsf.client.Browser.bFirefox;if(bFiref ox){vjo.darwin.pres*****ing.cmp.iframe.AegisDescri ption.init(1);}vjo.dsf.EventDispatcher.addEventLis tener(window,"load",function(){vjo.darwin.pres*****ing.cmp.iframe.Aeg isDescription.init(2);});}).endType();*********>*******>*******>********>********>
- it will work on any PC / Laptop not only on Toshiba T30,T40... like OPPS / OPS requires it
- works with DIS, INPA Ediabas, NCSExpert, SSS (Progman) and others
- all functions as in OMNITEC interface
- all cables are tested before shipping
You will get :
-one K+CAN OBD II cable that works on all BMW models from 1998 up to 2007
-one DVD with some evaluation software as Inpa 5.0.2, NCSExpert and DIS v44
-one CD with drivers
Step-by-step video and written instructions included
Those items do not include any kind of technical support after sales
- NO NEED of an expensive OPPS ( yellow head) or OPS (orange head)
Supported models:
  • BMW 1 Series E87
  • BMW 3 Series E46 E83 E90
  • BMW 5 Series E39 E60 E61
  • BMW 6 Series E63 E64
  • BMW 7 Series E38 E65 E66
  • BMW X Series E53
  • BMW Z Series E85 E52
  • Mini
Features:
  • Supports Double K-Line
  • Detects battery voltage through control line
  • Detects contact via control line
  • Works on USB port, USB RS-232 adapter not needed
Functions
  • Read fault codes
  • Erase fault codes
  • Service intervals reset
  • Real-time diagnostic lines status view
  • Code modules
  • Code ECU (daytime running light, seat memory to key, beep after locking)
  • Specific part tests (like a lambda or mass air flow sensor
  • And more..
Applications:
  • Works with DIS v57, INPA Ediabas v5.0.2, NCSExpert 3.1.0, SSS v32 (Progman) and others
Your package will include:
  • 1 x INPA / Ediabas K+CAN USB cable Interface
  • 1 x DVD with some evaluation software
  • 1 x CD with drivers
IMPORTANT NOTE :
  • we provide the package containing this car diagnostic and maintenance cable
  • we cannot give any support or advice on how to use this product
Your Shipping:
The items will be shipped in one business day by Standard International Post.
If you need them ASAP, you can choose DHL shipping but you will have to pay for the shipping price. For this kind of payment please contact me before buying the product.
******** type=text/javascript>vjo.ctype("vjo.darwin.tracking.sojourner.SojData").props({sojD:null}).endType();vjo.ctype("vjo.darwin.tracking.sojourner.CalData").props({setData:function(svcId,data){if(!svcId||! data){return;}this.cal[svcId]=data;},getData:function(svcId){if(svcId){return this.cal[svcId];}}}).inits(function(){this.cal={};}).endType();vj o.ctype("vjo.darwin.tracking.sojourner.TrackingRespHdl").needs(["vjo.darwin.tracking.sojourner.SojData","vjo.darwin.tracking.sojourner.CalData"]).props({handleResponse:function(msg){if(msg.error s&&msg.errors.length>0){this.vj$.SojData.sojD="";}if(msg.response&&msg.response.dataMap&&msg.response.dataMap.SOJDATA){this.vj$.SojData.soj D=msg.response.dataMap.SOJDATA;}if(msg.response&&msg.response.dataMap&&msg.response.dataMap.TDATA){this.vj$.CalData.setDa ta(msg.svcId,msg.response.dataMap.TDATA);}}}).endT ype();*********>
Old 07-24-2011, 12:28 PM
bluebee's Avatar
Originally Posted by Fifty_Cent View Post
BLUEBEE, how about these tools?
They're covered in detail in these bestlinks threads:
- Description of Carsoft, GT1, Progman, NCS, NCS Made Easy, INPA, DIS, EDIABAS, & Peake (1) & which can modify the auto-lock car door feature (1) & what does Carsoft do anyway (1) (2) (3) (4) (5)
Old 09-02-2011, 12:19 PM
bmwswag bmwswag is offline
Mein Auto: 328i xDrive
Bump
I actually started inquiring about ODBII readers to diagnose service engine lights in another thread. I just stumbled on this thread and was wondering if anyone had any experience with Autel MaxiScan MS300 on 2011 E90s, especially those with comfort access.
Order : 6/28/2011 Delivery : 8/13/2011
2011 BMW 328i xDrive
Black Sapphire Metallic | Leather Dakota Gray | Convenience | Premium | Navigation | Harmon Kardon | Heated Seats | iPod/USB
If you ain't gonna ride fly, then you might as well hate
