E34 (1989 - 1995)
Erratic idle
Just like tittle says... Erratic idle... Any ideas? Little vibration when pressing on gas...
Anything will help. Jorge |
Stomp test first to check for codes (if your 520 has it)
Vacuum leak, ICV ...
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
Can u walk me
Through the stomp test... Never done it.... |
See here:
http://www.bimmerfest.com/forums/sho...65#post5936965 Steve
I would do it like this. New Air filter,MAF spray in sensor and throttle body wile running. Intake boot must have both clamps. Check for sm 1/4 inch vacuum hose to pressure regulator at rear of fuel rail , they crack. Run a can Sea Foam 1/2 gas 1/2 engine. change oil and filter 50 miles later. If your plugs are over a year old check them for replacement. All this can be done for $60 or so and 2 hrs labor.
Thanks I'll try this today, or at least start today.
I had a weak coil that made mine do the same thing.......
