The X5 SAV Forum
Old 07-05-2011, 01:33 AM
ediddy22 ediddy22 is offline
Mein Auto: 2002 BMW X5
Door module, general module or both
I just got a bmw x5 2002 4.4i
My key doesn't work. I took it to bmw they reprogram the key, did all this things and it still
didnt work. They said the problem may be with the door module or the general module or
both. the key doesnt work for all the doors and the the trunk/cage, also the central locking
system doesnt work so i think its the general module. please help what should i do?
Old 07-05-2011, 12:09 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Find an indy with the right software interface to diagnose your problems, install the module/s and program them to the vehicle. ( If required.) A $tealer with that vague an answer does not seem to know what they are doing.
Old 08-05-2011, 07:49 PM
MNMRams MNMRams is offline
Mein Auto: 2003 Z4
Will the General Module also prevent you from opening the door mechanically?
Old 08-12-2011, 03:03 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
A couple things. Does the key in the door unlock/lock just the driver door or does it unlock/lock all the doors. When it unlocks/locks the driver door do you have to turn it a full 90 degrees or does the motor kick in at about 45 degrees? Do the interior lights work? Do they come on when the doors are opened? If it doesn't do they indicate door open correctly on the instrument cluster?
