E30 (1982 - 1993)
Old 07-05-2011, 11:28 AM
RevthisE30 RevthisE30 is offline
Mein Auto: 1986 e30
LSD issue
my LSD is making a whinig noise when i get above 20mph. i just changed the diff fluid and it is a little quieter but stills does it. i have read and researched these LSDs and everyone seems to say they are damn near bullet proof even with the whine. if anyone has/had the same problem please give me some more input. thanx
Old 07-05-2011, 05:16 PM
downhiller's Avatar
livin large
what kind of fluid did you put in? i think there is a specific fluid for lsds
Old 07-05-2011, 05:59 PM
Mein Auto: 1986 e30
lucas LSD 90w oil.
Old 07-05-2011, 06:40 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you sure its not your trans
the back of your trans can echo down your tunnel and make it sound like the diff is the one making noise.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 07-06-2011, 06:38 AM
Mein Auto: 1986 e30
Well i jacked up the rear of the car and removed the wheels and ran it through all the gears leaving it to spin in 5th. and it deffinetly sounded like it was coming directly from the LSD. Although i do know that my tran needs a new output seal it leaks fluyid through there onto my exhaust making it look as its smoking.
