7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
E38 / 1999-740il DSP / Nav / Radio issue?
Hi Guys,
I have a '99 740iL the radio would randomly come on and shut off. The GPS quit working, so thanks to this forum i started my research to fix my problem. I really wish all of these things were all separate ! oh well ! So after reading and trying my best, here is what I have done. 1. Checked the voltage of the battery, it has been replaced with a new battery. - Didn't fix the issue 2. I pressed the eject button and connected the power simultaneously - Didn't fix the problem. 3. Unplugged the GPS Nav mkII from the car and plugged it back in. Didn't fix the problem. 4. My dad has a 2001 740iL with the same GPS, so i plugged his unit into my car with no luck, I did put my unit into his car and the GPS /radio all work. So my GPS unit is not bad. So from reading the forums I have a few conclusions, 1. Either my dash display needs to be changed as i do have a few pixels that are bad, 2. Change the ignition as that could be the cause 3. The DSP could be bad. Note: the dsp does not light up on the monitor it is greyed out. Anything else you guys would recommend? I should try? Thanks, Raj |
try the e38 forum..you posted this in the e65 (2002+) model
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes, LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
| Bookmarks |
| Tags |
| dsp, gps, mkii, nav, radio |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
