99 740iL - Radio/GPS/nav not working - Bimmerfest - BMW Forums
Old 07-05-2011, 03:28 PM
99740il 99740il is offline
Mein Auto: 99 740 il
Hi Guys,
I have a '99 740iL the radio would randomly come on and shut off. The GPS quit working, so thanks to this forum i started my research to fix my problem. I really wish all of these things were all separate ! oh well !
So after reading and trying my best, here is what I have done.
1. Checked the voltage of the battery, it has been replaced with a new battery. - Didn't fix the issue
2. I pressed the eject button and connected the power simultaneously - Didn't fix the problem.
3. Unplugged the GPS Nav mkII from the car and plugged it back in. Didn't fix the problem.
4. My dad has a 2001 740iL with the same GPS, so i plugged his unit into my car with no luck, I did put my unit into his car and the GPS /radio all work. So my GPS unit is not bad.
So from reading the forums I have a few conclusions,
1. Either my dash display needs to be changed as i do have a few pixels that are bad,
2. Change the ignition as that could be the cause
3. The DSP could be bad. Note: the dsp does not light up on the monitor it is greyed out.
Anything else you guys would recommend? I should try?
Thanks,
Raj
Old 11-15-2011, 01:43 PM
Edrys Edrys is offline
Mein Auto: 2004 BMW 745IL
Raj,
I have the same issue with my 2000 740IL. Did you get to fix it? If so, please post how you fixed it or inbox me.
Old 12-10-2011, 09:37 PM
Lockdown4066 Lockdown4066 is offline
Mein Auto: 740il
I started experiencing several electrical gremlins in the past 2 weeks, to include radio/nav/cd player going on and off to include wipers and other items. I just replaced the ignition switch and all is well in Bimmer land. Good luck
Old 04-30-2012, 11:58 PM
So I have not had much luck as I put the car in non op mode. Now I want to fix it. I think Lockdown4066's answer could be correct. Lockdown was changing the ignition difficult?
Thanks,
R-
Old 05-01-2012, 04:23 AM
setconstr setconstr is offline
Mein Auto: 2001 740i spt 2008 cl550
Re:
http://www.bimmerboard.com/forums/posts/244045
dsp, gps, monitor, nav, radio
HTML code is Off
