Every domestic car owner takes for granted... - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 07-07-2011, 08:54 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Working windshield wash nozzles.
After five years of ownership, the 535i finally has a working windshield washing sytem again. My nozzles were plugged, melted, cracked....and the driver side one even had the audacity to explode the last time I checked function of the pump. Reservoir and plumbing were sound, so time to get new spray heads.
What a fiasco. The car has the heated type, so I order heated ones. They come in, but have dual inlets even though the part number said it's for the non-intensive cleaning system [single inlets]. Order another part number, they come with single inlets but have the wrong type of electrical connector. F*** this.. I cut the connectors off the new ones, and solder on the connectors from my old broken ones. Snap everything back in....like all 100 clips that fasten the hood liner in place.
Voila! Like the Bellagio
Good food, good people, good times.
Old 07-07-2011, 08:59 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
I have a 1999 E-39 and the washers work fine.
Old 07-07-2011, 09:05 PM
Radian's Avatar
Give it a while longer.
Old 07-07-2011, 09:20 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Yes the window spray heads are touchy. I found that each head has 2 pivoting nozzles made of lead or something soft.None of mine worked I found that the trick was 6 inches of 24gauge copper phone wire reamed the deposits out and allowed the nozzles to be adjusted .The adjusting can take longer than the cleaning.
Old 07-08-2011, 05:20 AM
Radian's Avatar
In case anyone was wondering about the title of the thread, I'm speaking from experience here.
Of the vehicles I've owned, all over 100,000 miles:
Non-working Nozzles:
- Two Toyota hilux 4x4's
- Toyota Celica
- Honda Accord*
- BMW 325is
- BMW 535i*
* Got them to work eventually, but performance is barely adequate, by my standards.
Nozzles that worked great:
- Chevy Cavalier
- Chevy Celebrity
- Ford Bronco
- Ford F-150
- Pontiac Grand AM
I'm not implying the later cars are better, or what have you....I'm just saying, that out of all the cars I've owned, the domestics have always had good, functioning windshield cleaning nozzles for whatever reasons.
Old 07-08-2011, 07:50 PM
Radian's Avatar
Correct inlet type, wrong electrical connector....but that proved only to be a minor inconvenience. If your car was made in September of 1990, you could run into this same issue.
Note: When removing your old nozzles, although the stainless clips that cinch the factory nylon-braided hosing look like the one-time use crimp clamps found on some fuel lines and radiator hoses, they are not. They are perfectly re-useable. The trick is to lever them off with a machinist's scribe [or other similar object] without bending the hook part beyond repair and to snap them back on using a pair of diagonal cutters.
Old 07-09-2011, 09:27 AM
Radian's Avatar
The part # of the spray head shown above in the previous message is 61661379203.
Below is the type I ordered first. They were part # 61668350355 Also shown are the old ones after I clipped off the connectors. Hopefully this will save someone a few days of driving around with a couple of empty holes in their hood waiting for the correct parts.
