E34 (1989 - 1995)
Old 07-08-2011, 06:49 AM
DLS_91_525i's Avatar
DLS_91_525i DLS_91_525i is offline
I Wonder What This Does?!
Send a message via MSN to DLS_91_525i
Mein Auto: 91 BMW 525i 72 VW Variant
Question BMW OEM wheels offset problems
I have found a local salvage yard that has a few BMWs that are wreaked and good for parts!
Well I think I'm going to go wheel shopping and was just wondering if any of the 5X120 bolt pattern wheels would have a problem fitting because of the offset?
We'll say 1989 to 1995 models.
Thanks for any help!
DARRiN http://www.facebook.com/E34DARRiN3391
(1991 BMW 525i 260,XXX miles)
(1972 Volkswagen "The DEATHWAGEN" Variant 64,XXX miles)
Old 07-08-2011, 06:55 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
E28/32/34 wheels will all work. 16" E38 wheels also but not with the E38 tires fitted.
3 series all have the wrong offset. E39 wheels are correct offset but wrong hub size, an adapter is available, they are called "hub rings" and readily available.
Lots of wheel fitment threads around but above is in a nutshell what you need to know.
Take my advice, I'm not using it.
Old 07-08-2011, 08:31 AM
So with E36 wheels does the offset cause the wheels to hit the inner fender wells before it connects with the hub?
Old 07-08-2011, 10:31 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Hare is some more info on what bmw wheels will fit your car
https://www.bmwe34.net/Wiki/tiki-index.php?page=Wheels
Old 07-08-2011, 11:29 AM
Sweet! Thanks!
