Old 07-09-2011, 11:00 PM
deepmallhi deepmallhi is offline
Mein Auto: BMW 745LI
Question Bluesmoke issue help
7 SERIES BLUE SMOKE ISSUE SMOKING WHEN IDLE MORE THAN 5 MINS BIG PUFF ON LIGHTS WHEN YOU TAKE OFF OR WHEN YOU HIT ON GAS HARD.
VALVE STEM SEALS - I HEARD AND MY KNOWELDGE SAYS IF ITS VALVE STEM IT SHOULD BE SMOKING FIRST THING IN MORNING WHEN YOU START THE CAR.
PCV OR CATALYK CONVERTER
IS ANYBODY GOT PCV OR CRANK CASE VALVE AND STILL SMOKED FOR WEEK OR SO.
NEED HELP IN THAT
Old 07-10-2011, 12:10 AM
7 Phi 7 7 Phi 7 is offline
Mein Auto: 2006 BMW 750Li
Mine is doing the same exact thing...My mechanic is saying something about the heads and a seal - I'm going to be leaving mine with him for about a week...He also mentioned that this happens withh all of the 7's, and that 7 owners should file a class action suit because it is a defect...
Old 07-11-2011, 12:46 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Your mechanic is talking about replacing the valve stem seals, which are on each head.
Regarding why bad valve stem seals would cause oil burning at idle, but not when you first start the car in the morning... If you look through some of the pictures from when I replaced mine (sorry I still don't have them organized still), you can see the location at which each stem comes out of the head is raised up above the head's main surface a bit, so, in order for oil to start building up and burning, the engine must be on and there must be vacuum pulling oil (or pressure in the crankcase / under the valve cover pushing oil) UP past the stem seals and to the area where the stem and head meet. Once the engine is off, any oil pulled up the valve stem seal would just fall back down.
Valve stem seals
New seal seated down into place (slightly below middle of pictures)
New seal popped up, about to be put into place
Valve stem without seal on
Parts I replaced during valve stem seal replacement (left to right... several VANOS adjuster compression rings, upper timing cover gaskets, spark plug tube, 2 bags of valve stem seals (did the entire engine, 1 bag per head...total: I think just under $200)
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 07-11-2011, 06:45 PM
i took it back to dealer he took 4 days from me to fix it ,he is saying he need to get catalyk converter cleaned and he say if in 4 days he cant get it fixed i can go ahead replace my car with any car in yard.
Old 07-11-2011, 06:47 PM
this is expensive job to do i was quoted $ 4000 to do valve stem and mechanic was saying sometime we need to replace guides too if we do another $3000 total $7000.00 tottaly dont want to go there.
Old 07-11-2011, 06:55 PM
Master Tinkerer
Yeah, it's a lonnnnng job, but $4,000 is pretty high. $2,000 I could see, but not $4,000.
Old 07-11-2011, 08:40 PM
kmatthews kmatthews is offline
Mein Auto: 750li
Hey Keif, I plan on changing the spark plug pipe due to the blue smoke on idle. What parts do I need to change while in there? And also I'm going to change coolant pipe too. I just want to know whats parts I will need and a rough price on parts. Thx in advance.
Old 07-11-2011, 09:13 PM
Thanks for the info Keif! My mechanic quoted me $4,000 also, and said it would take about a week to finish...is that accurate?
Old 07-11-2011, 10:48 PM
Master Tinkerer
I don't know that replacing the spark plug tube will change the blue smoke at idle... It shouldn't really impact oil getting into the cylinder, only oil leaking down onto the spark plug, which would only make the car run a little rough at worst.
Sent from my ADR6400L using Bimmer App
Old 07-11-2011, 10:54 PM
Master Tinkerer
Unfortunately yeah, it took me all day each day of a weekend, plus a few evenings. It's a freaking pain. $4,000 is steep though... $2,000 would be reasonable. Doing it again, it would probably just take a very full weekend.
Old 07-12-2011, 01:17 PM
7_up's Avatar
7_up 7_up is offline
Mein Auto: 745 Li
I agree with lied $2k is more reasonable
Old 07-18-2011, 09:08 PM
i end up getting my 745 fix.dealer gave me another car for week and he said he will fix it.i had chat with him today he said mechanic is saying its EGR so he is saying he will get that replaced n let me know by tommorw,but i am telling him about valve stem seals he is saying mechanic said there is nothing wrong with valve stem and rings.i crossed my finger n hope my car get fixed n finally get my boing 745 back.
Old 07-19-2011, 11:08 PM
Master Tinkerer
I'll be curious to hear what EGR piece he suggests replacing, or what he does to fix it.
Old 11-22-2011, 02:42 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
So keif I have the same problem my cars idles and I see blue smoke and when I'm at a light and take off blue smoke . So I should replace valve stem and valve stem seal ?
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
