The X5 SAV Forum
Old 07-09-2011, 11:42 PM
serkan serkan is offline
Mein Auto: bmw x5
x5 window problem
my 06 x5 pasenger side window i cant roll up when it goes all the way down, if i pull it with my hand it rolls up slowly, everything is normal if i dont roll all the way down.when i roll down driver and pasenger side driver side is about 1 cm higher thn pasenger side n when i try to roll up or down it moves 1 cm plz help
Old 07-10-2011, 12:07 AM
marco328 marco328 is offline
Mein Auto: 99' 328i (E46)
Sounds like your window regulator is failing. I've replaced all mine in my 328. The front ones at least 2 or 3 times. You'll have to remove the door panels to see exactly what the problem is. If it's just the cabling then you can do it yourself if you have some mechanical abilities or take it to a trusted mechanic. Good Luck!
Old 07-10-2011, 12:12 AM
bmwMobiletech bmwMobiletech is offline
Bimmerfanatic
Mein Auto: 1995 bmw m3
Window needs to be initialize. I recommend for you to take to dealer or shop with gt1 or isss software. They have to do it through comp for better results. They also have a way to initialize it manually by holding window button down for up for 12minutes. Good LUCK!!!
Old 07-10-2011, 03:23 PM
Mein Auto: bmw x5
thx guys
Old 08-19-2011, 06:53 PM
Mein Auto: bmw x5
update
it was window regulator clip, b4 u take it to dealer open up n take a look inside
Old 08-20-2011, 02:52 PM
Bimmerfanatic
WOw, im glad you found the source of issue. That also works to...
